l series transfer problems
banger
Post by banger » Sun Oct 04, 2009 6:26 am
hi all im new to this site nt new to suba's im on my second i have an 89 l series 2" lift on king springs and 27" bfg all terains. had lots of problems of late with a subaru mechanic not being able to do wheel bearings. they have done them 3 times so i did it myself this time.
but the problem i have at the moment is she dont like going into lows. it sometimes goes in better when rolling but its the luck of the draw. any thoughts would be awesome.
banger
Post by banger » Sun Oct 04, 2009 6:28 am
and if anyone wants a set of winter treads i have a set of 4 185 70 14" nankangs will fit under non lifted suba.
Post by AlpineRaven » Sun Oct 04, 2009 9:53 am
can you tell us more about why she wont get in low gear?
Are the tyres all the same size?
Has the gearbox been changed/or diff (has to be matching ratios)?
Are you on gravel or off surface to get in low range?
openflame06
Post by openflame06 » Sun Oct 04, 2009 1:57 pm
---- Winter treads are they new?
banger
Post by banger » Sun Oct 04, 2009 3:33 pm
it doesnt matter where i am all the tires are the same size and i never used to have the problem. i push the lever up and it is like when you get in between hi and low. hi is fine but its no good to me with 27's. all the gearbox and diff is standard.
and the winter treads have at least 80% left on them
banger
Post by banger » Sun Oct 04, 2009 3:41 pm
i'd post a pic but i'm not sure how i only want like $90 for them they are on ebay my user name is malachijj85
openflame06
Post by openflame06 » Wed Oct 07, 2009 6:47 pm
Yeah its way too far for me to go otherwise id be keen.
phillatdarwin
Post by phillatdarwin » Wed Oct 07, 2009 9:56 pm
i wood like to tyres but i are in darwin
Post by El_Freddo » Thu Oct 08, 2009 12:01 pm
Check the 4wd lever links - there may be a shagged out bush in there somewhere that's not allowing you to select low everytime you want it.
Post by TOONGA » Thu Oct 08, 2009 12:57 pm
http://cgi.ebay.com.au/185-70-14-Mud-an ... 911.c0.m14
link to tyres (nice tyres)
no rims :(
