can anybody help me with this out of ideas
Posted: Thu Oct 01, 2009 10:27 am
by subaru_crazy
Posted: Thu Oct 01, 2009 12:46 pm
G'day Crazy!
$500 for a 99 foz?! That's insane, even with the flooding of the motor - I've read the posts in the link you gave.
The next thing I think you could/need to check is the cam angle sensor, crank angle sensor and to make sure that the cam belt is properly aligned - if the belt has skipped a tooth it will run poorly.
Have you checked all the other sensors - knock, o2 (exhaust), temp and throttle posistion sensor? If the motor spent some time partly submerged one or more of these sensors may be water damaged, best to check them all out to see that they are working as they should be. If you don't have a manual, get hold of a gregories or haynes manual - these will have the specs of each sensor's correct operating perametres that you'll be able to test for with a multimetre.
Other than that I'd be making sure that every plug is free of water damage/dirt etc with a bit of WD40 or the like.
Good luck with it, I love a bargain, even if you need to work on it ;)
Posted: Thu Oct 01, 2009 3:16 pm
by TOONGA
you need to go through and one at a time unplug and clean every single plug you have on the motor/ engine bay
start with the throttle body when you do this have a can of wd40 and a soft tooth brush ready if there is green corrosion on the brass tabs of the plug spray it with wd40 and then brush it gently until the corrosion is lifted you need to do this with the male and female parts of the plug
I had a similar problem with my wifes liberty after I power washed the engine it dried out but didn't run properly for 2 days until I cleaned all of the little plugs
it was so much fun I've never degreased that engine again :)
Posted: Thu Oct 01, 2009 4:51 pm
by AndrewT
Good advice so far.
Surely the ECU is producing some error codes...Does the check engine light come on?
Posted: Fri Oct 02, 2009 2:17 am
by subaru_crazy
i put new plugs wires ecu and coil fuel pump the timing is dead on it runs just wont idle and kindof boggy
Posted: Fri Oct 02, 2009 9:29 am
by TOONGA
you may have changed the spark plug leads, ecu etc but have you changed the wiring harness (a complete re-wire?) thats why Ive suggested cleaning all the little terminals on the engine and as has been suggested have you changed the oxygen sensor on the exhaust?
when the engine runs what sort of exhaust does it have?
is it continually steamy or does the steam go away when it heats up?
you may find that when it was started to clear the engine the water pressure may have bent a valve (yes even with the plugs out this can happen)
Posted: Fri Oct 02, 2009 10:00 am
by subaru_crazy
i havent changed the o2 yet but i will tomarrow i think i need to do some waterproofing b4 i go out again is there a thread about what to water proof and how i know that the ecu to be sealed and higher mounted snorkel for engine and vent tubes for the tranny and the diffs but what else
Posted: Sat Oct 03, 2009 11:01 am
by frogstar7055
Did you have water in the cab?
Did the ECU get wet?
Posted: Mon Oct 05, 2009 1:04 am
by subaru_crazy
yes all the way up to the seats so i drained it out replaced the ecu with a new one from a salvage yard it has all the same #s as the old one dont know what else could be wrong with it
Posted: Mon Oct 05, 2009 9:31 am
by AndrewT
AndrewT wrote: Surely the ECU is producing some error codes...Does the check engine light come on?
Posted: Mon Oct 05, 2009 3:27 pm
by tex
just wondering if you've drained and checked the fuel at all? also was it flooded in muddy or clean water? see what else is said but if you think its a bent valve a compression tester should pick it up and most mechanics will have one of these! or if you still think its fuel remove and get the injectors cleaned (cheap to have done) but do the filters as well although these things are unlikely it saves doing them in a service later!
Posted: Tue Oct 06, 2009 2:27 am
by subaru_crazy
It has 150 psi in every cyl fresh gas and filter replaced injectors with ones i had on another motor still wont run right i think this is a lesson i learned the hard way
Posted: Tue Oct 06, 2009 8:47 am
by AndrewT
Is it displaying any check-engine codes?
Posted: Tue Oct 06, 2009 12:48 pm
AndrewT wrote:Is it displaying any check-engine codes?
Want to tell how to check error codes?
Posted: Wed Oct 07, 2009 2:13 am
by subaru_crazy
the only two codes poping up on my computer are fuel level sensor and po440 evap emision no other codes
Posted: Thu Oct 08, 2009 2:14 am
by subaru_crazy
i think im going to give up on it ive tried everything i can think of plugs wires ecu coil maf tps iac cam sensor crank sensor i dont know what could be wrong thanks for the help guys
