EJ20T running half boost
Hey Guys,
EJ20T in Brumby now with recently replaced plugs and timing belt has recently started running / being limited to half boost, (5-6 PSI) unsure if the check engine light should come on if theres a fault or if I need to check fault codes to determine?. Engine is Jap import, standard ECu, etc running premium fuels with octane booster.
Any ideas appreciated.
- Outback bloke
- Outback bloke
That sounds like it should be fine. Next test is to trace the line that runs from the compressor housing to the boost controller. I think it is the one that comes in near the bottom of the controller at right angles to it.
Now this sounds a bit dodgy but it does work. Drill a small hole around 3-4mm in diametre in the rubber hose just before the controller. Make sure it is not on the pipe from the controller. What you are trying to do is bleed off a little air pressure before the boost control system.
Take it for a drive. If you have the correct line you should see an increase in boost. If you do get an increase and it is running how it should then your boost controller (bleed valve) is malfunctioning.
Second, if you have drilled the hole close to the controller you can now trim off the end and slide the hose on so the hole is gone.
If when you are driving it the car takes off like a rocket and then jolts it will be an over boost protection that is built in to the ecu. This will only happen if the hole you drill is too big.
Also, is your check engine light working/connected? If it is and you aren't getting any codes then it does sound like a faulty bleed valve or waste gate.
If it isn't connected it could be a number of things and you need to get it working.
Havent had time to check mine further due to work. Not sure if it may be temperature related as we have been having considerable hotter days here in SE QLD and the factory Top Mount INtercooler needs proper scoop and better flow... Might need to take it out early morning / evening to see how she runs.
						How likely would it be for the timing belt to have jumped a tooth since recent replacement? Car seems to drive fine but limited to 7/8 PSI which is damm frustrating. Noted that car also seems to have a very very minor shake to it when idling, dont really want to take the radiator out if not likely to the belt??
Any thoughts...
						Any thoughts...
- Outback bloke
The fact that an ECU reset temporarily resumes the standard boost level for a short while suggests its entering 'limp mode'
Are you using 98 RON fuel?
Have you checked for codes?
It might be worth your while checking out Ozliberty.com
There are quite a few members there with turbo subes
- Outback bloke
Yeah sorry, my mistake
That could be you probelm
The ECU could be confused because the TPS is telling it full throttle, but it isnt getting its signal from the accelerator switch.
Find the 'accelerator switch wire, and tie it somewhere near the accelerator pedal so that when you give it full pedal, it should emulate an accelerator switch
If you want a propper switch, the kickdown switch from 3speed auto MY's will fit your brumby
i would try:
1. connect a hose directly from the turbo output to the wastegate. this will give you wastegate boost only. see how it goes and if it is any different to the problems you are experiencing - if it is no different - there is something wrong with the boost control solenoid/vacum lines/wiring etc.
2. if you have a manual boost tee install that (make sure you install it in the correct direction for the airflow from high pressure side of turbo to wastegate) and screw it all the way down (ie: lowest boost) go for a run and see how the boost goes - then undo it 1/2 a turn and go for a run - you should see higher boost - do this a few times until you get to target boost (say, 3rd gear) and then see how it is running in 1st/2nd. if it is all ok - same prob as above - solenoid, wiring or plumbing.
to turn off the code in your ecu, if you have an obd-II port download a program like ecu-explorer, copy the ecu rom and locate the sensor code in the rom - you can select an option to turn that code off and reflash the ecu (i think you need ecu edit or similar program for this) and then you will never see the trouble code again. i doubt it is related to your boost problem. check out some of the open source tuning forums for the exact names of the software etc but you need 2 programs to do the reflash. i did it on my forester when i kept burning the egt sensor in my up-pipe - just turned off the trouble code and everything is good now.
