Identify this gearbox
H-top
Post by H-top » Sat Aug 22, 2009 9:16 am
I bought a vortex gearbox recently. All the company knows about it is that it came from a vortex.
I want to know how i can tell if it's selective four wheel drive or fulltime?
H-Top
rolling in
Post by steptoe » Sat Aug 22, 2009 10:58 am
If it got more than one selector lever I'd say it is selectable 4WD as in FWD until you select the rear wheels in (important that it has a rear output for this:) ) Wonder if they have the VIN and if that would help.
FROG
Post by FROG » Sat Aug 22, 2009 11:15 am
VIN always helps
Post by AlpineRaven » Sat Aug 22, 2009 3:26 pm
Isnt there any gearbox number on the left side near starter motor area is?
H-top
Post by H-top » Sat Aug 22, 2009 5:29 pm
single range :) thanx for your help
cheers
H-Top
rolling in
discopotato03
Post by discopotato03 » Sat Aug 22, 2009 10:07 pm
If it's an AWD one it will have the actuator bolted on one side and a cable running to a linkage on the drivers side down low towards the rear if its extension housing .
I have one of these in the cave at home and can have a look/check sticker number tomorrow afternoon .
Cheers A .
PS from memory behind the exhaust hanger bracket there is a three eared cover plate on the back of the lower extension housing .
