mixture; L-series Dec85, ea82, carb
Posted: Sat Aug 15, 2009 3:06 pm
by rafnics
Do you drill through the top of the "mixture screw cap" to get at the mixture screw? Or can I pull it off if I pull the carby out (again)?
There's a bigger story... basic amateur carby overhaul; now have backfiring in exhaust when changing gears up unless I'm very gentle. Played with timing and distributor is now at full rotation.
Seem to be using more fuel, have a fuel smell, and what seems like fuel smoke. I've put the hose onto the carby while running and nothing happened, so I'm taking that to confirm that I sealed it back up ok.
Maybe there are other things I need to check (new spark plugs, leads, ...), but this all happened after I cleaned the carby out, and really looks like too much fuel going in to me (but, then, I'm pretty amateur even on my good days!!)
cheers,
Francis
Posted: Sun Aug 16, 2009 11:15 am
by Busdriver
Drilling out the cap to get at the mixture screw wont help by the sound of it, you have a problem somewhere else in the carby. The mixture screw only changes things at idle.
Sounds like its runnung too rich. You may have a thing in the carby thats called a power valve in the bottom of the float bowl. It is usually closed and a drop in manifold vaccum, ie full throttle, is when it is opened and it may be not shutting properly now and therefore letting in more fuel than what is required.
