Help replacing front oil seal, ea81
im wanting to replace the front oil seal on my brumby. but im having trouble geting the bolt undone that goes into the crankshaft. i thought it must be done up very tight but have been told it may have a reverse thread. can anyone verify this?
cheers
matt
cheers
matt
confirming what tony says. normal right hand thread, 22mm socket generall fits the bolt head and a 450mm or 600 mm breaker bar with the handle set up on the lhs of the car. I shove it through the tow hook to hold it in place. WARNING is just a click of the starter will do and remove radiator first to prevent any accident and kill ignition. do it in neutral
Use a rattle hammer gun if you have one or access to.. thats the safest way of undoing it.
- ScubyRoo
Not sure if the EAs have access to the fly wheel through the bellhousing or not? Check for a little removable plastic cap near the engine-transmission join - it might only be on the ej series... I shoved a big ol screwdriver in there which my dad held in place with a crowbar. This stoped the crankshaft from spinning and I used a 3m breaker bar (peice of steel tubing i found behind mitre 10
). But my engine was out at the time...
- openflame06
Seriously if you can get a rattle gun. To give you and idea, I have an EA82 and the bellhousing hole in the gearbox.
I jammed it with a flat blade screw driver and had all of my weight on the spanner pushing down - i was literally balancing on it and i had to push down whilst balancing.
It did crack in the end, but it took a heap of force to do it.
