Wrong time, wrong place - cooling, leads and engine problems
Posted: Sat Jun 27, 2009 10:34 pm
After an extremely epic rafting trip, my trusty '92 Lib GX gave me the first trouble I've had in 2 years, a long 6 hour drive from the NSW/VIC mountains back to frankston.
a slow rise of the temperature needle signaled something was up as its never budged passed middle. Popped the hood and found that the engine to radiator main hose was steaming with a small split opened up. Duct tape sealed it up well and topped the radiator up with water.
10 minutes later car loses power and knocking sound from engine before whole engine stalls at 60kmph. Pull over and pop the hood, only a little smoke with very little smell. Check the spark plugs - yup, leads on 4 and 2 plugs have popped off. Strange, I think, as i've never heard of something like this happening. Shove em back on and make sure they've sealed on well.
A few hours later after the car was parked it refused to start again. I figured dead battery, so we jumped it and drove a few hours (we were returning from a rafting trip), with the car turned off and started a few times without any troubles. 100km later the duct tape gives up the ghost and the hole sends steam, coolant and water spraying. Tried another duct tape job, added more water but it only lasted a few kms before over heating again.
Replaced the hose at a subaru dealer in Seymore and had it checked by them - 'yep, all good now'. Temp gauge was steady middle. 20kms out of Seymore toward melbourne and the needle heads back up again - bugger. Waited for the engine to cool and put about 3 litres of water through the radiator, guessing there was a decent sized airblock in there somewhere. Did the cool, fill, run process several times. Had to push start on the last time it overheated to restart.
Spark plugs popped 2 more times, always accompanied with overheating.
Called RACV, he came and did the same thing we did. Car refused to start again, not a single tick. RACV said alternator is dead. Jump started by RACV, air settled out of radiator and temp guage stayed steady, so he sent us on our way. 10kms later we're on the side of the road again, over heated, dead battery and 2 spark leads popped (at the engine end). Called the flatbed and the car is now sitting in my girlfriends drive way waiting to get back to frankston.
There has been a slowing leaking of transmission oil over the last few weeks, engine oil is steady, not loosing power steering fluid. Small amount of white residue on inside of oil cap. Vapour in exhaust fumes. Scum on radiator cap and around opening. Radiator is OEM installed feb last year with coolant that was supposed to last 2 years before being replaced by the radiator service centre. Left inner-CV boot replaced last week.
Any ideas as to what the damage might be?
I'm in a shocking state as I just forked out for the body lift a few days ago and have just accumulated everything but OB trailing arm mounts and have a very empty bank balance. I'm a povo uni student and pretty much spent most of what i've saved up on the mods sitting in the garage atm.
I'm not very happy with my mechanic as I asked him to look into the leak when the CV boot was replaced and nothing was picked up. Does anyone know of a mechanic in the frankston area they've had good dealings with?
Is there anyone with the knowledge that would be willing to help me DIY? I can pay for your time with limited cash or slabs of your preferred beverage and many grateful thanks.
Thanks for any advice or possible help!
Owen, the very disappointed and impoverished subaru owner.
