ea82t questions
Posted: Wed Apr 22, 2009 11:04 pm
so i've almost finished putting my ea82t together to make my rx go, but i've been making the the motor from mainly one engine but have the orig stuffed one that i need to take parts from.
the stuffed one had previously had work done to it from what i could see (head work) but also had a whole lot stripped of the intake manifold so my questions are...
and
from the orig intake are in the first pic it is blocked of by a plate (mine has something attached) is there a benifit to block my other intake in the same way?
and the second pic altho this little do'dad is on both intakes, it is not plugged in via vaccum line like the other i have. can i remove the whole vac line as both items are linked on the same line?
and last but prob not my last question on these motors...
the pipe that feeds in to the base of pic one in to (or from) the exhaust one motor has it, the other doesnt.. can i remove it?
were ever i have talked about removing lines/pipe i understand the origins will need to be blocked.
and
