Automatic choke
Posted: Wed Feb 08, 2006 9:19 am
by LTurbo
Is it possible to adjust a automatic choke?
When I start the car up in the mornings it starts idling up at 2grand until the engine warms up. 2grand seems a little rough to me on a dead cold engine, I'd much prefer if it was 1500rpm or something.
Does anyone know what its supposed to idle at?
This is on a 89 ea82T.
Posted: Wed Feb 08, 2006 10:11 am
by BlackMale
MIne has ALWAYS been between 1500 and 2000 - thats fine. Sometimes i have noticed that on a slightly 'fresher' morning it will be a little higher.
I would think that there is little to worry about - it sounds like it is the first time it has done this so just monitor it over a few days and see what you get.
Posted: Wed Feb 08, 2006 10:49 am
by LTurbo
Jaffa wrote:it sounds like it is the first time it has done this so just monitor it over a few days and see what you get.
Nah, its been doing it ever since I have had the car (not all that long) and has always been at 2grand or just under. I was just curious as to whether the idle at 2000rpm was standard or whether it had been fiddled with at some stage.
So you know of no way to adjust it? I don't think you can.
Posted: Wed Feb 08, 2006 11:37 am
by subarursliberty
My leone was around there when I was driving before the conversion started. I wouldn't waoory about it. My RS get driven out the garage down the drive firts gear 2000rpm 2nd 4000rpm full boost. She's still singing sweet.
Posted: Wed Feb 08, 2006 12:07 pm
by BlackMale
OK 2 g is still ok though.
Posted: Wed Feb 08, 2006 12:33 pm
by MUDRAT
It's actually not a choke in the true sense of the word - it's your throttle bypass valve - and I'm sure you can adjust if you want. Not sure how on an EA82 turbo however.
Posted: Wed Feb 08, 2006 12:43 pm
by BlackMale
same as the EA82.
Posted: Wed Feb 08, 2006 1:00 pm
by LTurbo
MUDRAT wrote:It's actually not a choke in the true sense of the word - it's your throttle bypass valve - and I'm sure you can adjust if you want. Not sure how on an EA82 turbo however.
Cheers for that Nathan, i'll read up on it.
Posted: Wed Feb 08, 2006 5:51 pm
by steve_rising_sun
The only way to adjust it is to put a 5/8 LPG main vapour line adjuster in the hose to or from the idle up device.
Steve
