97 Outback Engine troubles
Posted: Sat Nov 29, 2008 2:31 pm
by Giffo
Gday all, Im Giffo and new to the forum.I have a April 1997 Outback,Engine Type EJ25DNACJA,and the motor is coughing and spluttering then either cutting out alltogether or it will stop spluttering and run normal.The symptoms are just like it is running out of petrol.When the motor stops it will start straight away with no problems.I have had it to 2 mechanics (not subaru dealers) and they had it on computer with no problems,relaced spark plugs,fuel filter,air filter,tested the pressure of the fuel pump.This problem can happen 3 or 4 times in a few Ks or run for a hundred with no worries.Then as of yesterday, it will not go into park only as far as reverse.Any help would be greatly appreciated.
Giffo
Posted: Sat Nov 29, 2008 4:01 pm
by Matatak
Fuel pump?
Posted: Sat Nov 29, 2008 5:04 pm
by Giffo
The last mechanic tested the pressure of the fuel pump and it was OK !
Giffo
Posted: Sat Nov 29, 2008 5:32 pm
by Matatak
could be intermittent though.
Posted: Sat Nov 29, 2008 8:45 pm
by Outback bloke
Could be a number of things. Maybe fuel pressure regulator playing up (drivers side at the back of the inlet manifold), possibly the vacuum hose on it or it could actually be the fuel pump or ignition relay malfunctioning (inside the car - A pillar - right up behind the fuses - PITA to get to - fuel is a round canister and will have a green plug going to it, ignition is a brown squarish box right beside it) , loss of power to the computer (passengers floor at the front where your feet go). Or, another one that is a little more common is the electrical connection under the back seat, drivers side, where it goes through the body and down to the fuel pump.
Is your dash lights coming on when it happens? Fuel guage still working?
Posted: Sun Nov 30, 2008 7:43 am
by Giffo
Outback bloke
The fuel gauge is working.No dash lights come on when the car is coughing and spluttering.I will try what you have said,Thanks.
Giffo
Posted: Sun Nov 30, 2008 1:24 pm
by AndrewT
Giffo wrote:Then as of yesterday, it will not go into park only as far as reverse
This would almost definitely be unrelated to the spluttering problem. This could be a problem with your shifter linkage, perhaps a collapsed nylon bush.
For spluttering try swapping for a known working air flow meter, often they can cause issues like that without causing the ECU to throw any engine codes.
Posted: Wed Aug 05, 2009 7:20 pm
by dirty skirt
hey giffo i was wondering if you sorted out the problem cause my car started doing the same thing a couple of days ago (same car).if you have sorted it what was the problem
cheers steve
Posted: Sun Aug 09, 2009 10:36 pm
by dirty skirt
hey guys any other ideas of what the symptoms can be cause i checked these and its still doing what was explaned ate the top of the page
all help is greatly appreciated
thanks steve
Posted: Sun Aug 09, 2009 10:38 pm
by dirty skirt
by the way i have used the subaru upper engine cleaner as per directions and stiff doing problem
