Surging Under Accelleration
Gday all ye wiley in the ways of L Series.
I am writing for some advice. I have put up with it and it is finally giving me the poo poo's. When accellerating the L series is sometimes surging, a bit like it is hunting for revs...if I keep going up in revs, it seems to iron itself out but it is really starting to annoy me.
The car is a MPFI Touring Wagon - I have replaced the fuel filter and the leads. Can the one or all the following be the culprit:
a: Fuel Pump(Bosch 65psi hi vol - about 100k kms)
b: O2 sensor
c: Fuel injectors
d: Other!!
Any advice would be greatly appreciated. I reckon it is the fuel injectors personally - I dumped a tank of Vortex 95 in the tank with some flashlube to see if it will make a difference.
Hooroo
Rob
b: O2 sensor
c: Fuel injectors
d: Other!!
Hooroo
Rob
Rob Forsyth
- INEEDABEER
Yepp codes are all sweet and I will pull the tank access off to check for water although I think it probably might be the O2 sensor - it looks very ordinary and I suspect it is the original one....
Any idea as to cost and where to get them? I saw an ad in Just Parts for O2 sensors but no prices...may have to go OEM and hit Subaru in Phillip up.
With the fuel injectors, is there another brand I can use other than the standard replacements? They are bloody expensive little sausages!!!
Hooroo and thanks for the help!!:)
Rob Forsyth
Get your fuel injectors serviced, costs about $25 each
As for your o2 sensor, you can get universal ones off ebay for cheap, and they do the job
I bought one of these OXYGEN-SENSOR-O2-SENSOR-SINGLE-WIRE-UNIVERSAL and it works great.
