car vibrating over 60 kmh
dj fbi
Post by dj fbi » Sun Oct 19, 2008 7:05 pm
I took my subie up to the beach (DI) today had a ball,but i got back on the road and of the sand the car started vibarate at about 50 kmh its coming from the frount of the car,there does not seem to be any play in the steering wheel when the car is stoped i can turn the wheel tith no play in it at all,there is no play in the cv's that i can tell,but i did notice when i rock the car side to side the driver's side frount shock make's a knock sound up the top,the rubber hat is pritty old and has a few small crack's and pulling on the top of the wheel you can here it knock,will this mack my car shutter on the road.
[SIGPIC][/SIGPIC]1991 L series touring wagon, ea82t,tdo4,tmic,vl 380cc injectors,adjustable fuel pressure regulator,pod,5 speed rs turbo awd gear box,lsd diff,3 inch zorst to big ass cannon ect.. my baby
Bumpty
Post by Bumpty » Sun Oct 19, 2008 7:16 pm
What rims do you have, it could simply be that there is sand clump/s sitting on the inside of your rim, thus making the rim unbalanced and making the car vibrate.
Could give the car a burst with a pressure hose around the shocks, behind wheels and clean it all. Can only help.
INEEDABEER
Post by INEEDABEER » Sun Oct 19, 2008 7:18 pm
Do you still have some sand on the inside of the rim,sometimes it will stick there.
]Hey I know Jack Schitte!
[/SIZE]
dj fbi
Post by dj fbi » Sun Oct 19, 2008 7:26 pm
No sand,when i got home gave it a good wash, it vibrate's alot it makes the steering wheel shake, it was a slow drive home
the gumbi brumby
Post by the gumbi brumby » Sun Oct 19, 2008 7:53 pm
sounds like ballance as others have said
check lower ball joints
roscoruby
Post by roscoruby » Sun Oct 19, 2008 10:02 pm
I had a vibration in my subie that started at about 50 k/h in the front end. Rick and I searched to see if something was loose found the front uni joint had play in it. We replaced it & vibration is gone.
May be worth checking yours out.
Ross
1996 Gen 2 liberty Wagon, manual with L series low range Awd and vlsd .
dj fbi
Post by dj fbi » Mon Oct 20, 2008 6:39 pm
Hi there all,SAND sand sand on the way to work today the car was still vibrating i pulled over went over the car and found a small bit of sand about the size of a $5 note and about 1 centermeter high stuck on the inside of the frount lh side rim rubed it of and she's back on the road again without the vibration.thanks for the heads up on the sand.I love this site.
the gumbi brumby
Post by the gumbi brumby » Mon Oct 20, 2008 6:44 pm
simple fix
INEEDABEER
Post by INEEDABEER » Mon Oct 20, 2008 6:47 pm
Knowledge is power.
[/SIZE]
bretgc
Post by bretgc » Tue Oct 28, 2008 8:54 pm
hmmm maybe i should have checked my uni joints while my car was up in the air...another job for the boys at bridgestone me thinks!
