EA82 injector problems
H-top
Post by H-top » Wed Oct 01, 2008 5:19 pm
i've got an EA82 non turbo with blocked injectors i think. When i turn over the engine, the fuel pumps initial burst of fuel is enough to start running for a few seconds and then dies, Unless i'm foot to the floor revving the guts out. Also, whats the standard flow in CC's of the injectors for that engine.
H-Top
rolling in
H-top
Post by H-top » Fri Oct 03, 2008 11:18 pm
I'm only assuming they are blocked, any ideas on any other possible problem? I've changed pump, filter and flushed the tank
H-Top
rolling in
rob83ke70
Post by rob83ke70 » Sun Oct 05, 2008 8:27 pm
when you start it with your foot to the floor and rev it hard to keep it going, does it sound healthy? does any grey smoke come out of the exhaust? will it return to idle at all? when you floor it does it "stumble" and missfire until its revving really high?
i take it the fuel pressure and flow is ok? is the residual pressure ok? is spark and plug condition ok? is your ignition timing/cam timing all ok?
H-top
Post by H-top » Mon Oct 06, 2008 9:57 am
It sounds off. Nothing like the normal note. No grew smoke or minimal. It does missfire until in the high range. Flow is good untill the injectors. Spark is good. Timing is good. Drove it good from work. Waited an hour and then this happened when i tried to start it
H-Top
rolling in
H-top
Post by H-top » Mon Oct 06, 2008 9:59 am
It does stumble too
H-Top
rolling in
rob83ke70
Post by rob83ke70 » Mon Oct 06, 2008 6:59 pm
coolant temp sensor maybe? or o2 sensor?
does it come good again, and then play up again? or is it just playing up all the time now?
all the plugs still look ok even after its been playing up?
haven't got any hoses disconnected in between the air flow sensor and the manifold? (do they have air flow sensor or map sensor?? i'm not sure), check for any unmetered air into the engine.
i do cheat a bit in these situations, i have a four gas analyser at work, pretty easy to tell if its rich or lean and whats causing it (most of the time)
Post by Gannon » Mon Oct 06, 2008 8:45 pm
Unplug your air flow meter (located just after the air filter) and start the engine, if it runs better, your air flow meter is dodgy
H-top
Post by H-top » Mon Oct 06, 2008 9:04 pm
I'll check all those, currently charging the battery.
will report back on wednesday.
-crosses fingers-
Thanx so much for ur help so far!
H-Top
rolling in
H-top
Post by H-top » Tue Oct 07, 2008 7:23 pm
I got noooo idea what the problem was,
I just unplugged and replugged everything and
it all worked. I believe it was the AFM
Thanx so much for ur help guys,
without it. I would have
had to drive the work Falcon
for ever! NOOOOOOOOOOOOOOOO!
H-Top
rolling in
Post by Gannon » Tue Oct 07, 2008 9:40 pm
Thats good to hear.
That would be the 3rd time unplugging the AFM has worked
I dont know why it is, but it just works
rob83ke70
Post by rob83ke70 » Sat Oct 11, 2008 11:16 am
slight build up of corrosion on electrical terminals in plug, when you unplug and re plug the connector the friction cleans the terminals and the problem goes away. the other one to watch out for is loose pin grip within a plug... all sorts of weird intermittant problems....
