Clutch slipping or not?
Hi guys, thought i'd post this up for some advice.
I have a 92 L wagon and it was fine until I stopped at a set of traffic lights a few hours ago. When the lights turned green and i let off the clutch with some gas as usual, I couldnt get any bite on the clutch at all. The gearbox gives a fast rattling/knocking sound like some metal thing hitting a propeller constantly when I rev the engine and let my foot off the clutch pedal. This was in front wheel drive mode and was about to call a tow truck when I decided to try 4WD. Theoretically I didnt expect it to work but it did! Clutch bites and the car moves as per normal in 4WD mode.
Now im not an expert but isnt the rear wheel drive behind the clutch as well? My rear wheels shouldnt be moving the car if it was a worn clutch slipping right?
Secondly, symptoms of a worn clutch should have been gradual and noticable instead of being so sudden? I also suppose a slipping clutch should sound more like a grinding noise instead of knocking.
Would appreciate any advice on this. Thanks!
Calvin
Calvin
- Suby Wan Kenobi
i would say cvs because ive had a bad run out of reco cvs in my eyes your beeter off goin new ive had mine in for nearly a year and they are goin good no clicking at all yet
92 brumby, 2" lift, 30" cooper stt's, 2000 ej20, lib seats, compressor, uhf, trayliner, 2.25 zorst,L series 5 spd 3.9 ratio, wrx viscious lsd, imprezza pwr steer.
yep, it's a front CV for sure.
I think you can stop worrying about the clutch anyway- no clutch = no go in 2wd or 4wd.
Pardon my ignorance please, but if it was a front cv or any thing to do with a front driveshaft, why would it not make the same noise in 4wd as it does in 2wd? They are still turning arent they?
Suby Newbie
Suby Newbie
- INEEDABEER
put your car in low-range 4wd. Pull up the handbrake and do a big massive skid! lol
your cv shaft has broken. GUARANTEED!
because in fwd its trying to drive the front wheels.....slippery diff means drive goes to blown joint = noise
in 4wd front and rear split is the same so the rear drives the car and the front wheels turn as well the same speed as the CV, last time i blew a cv i didnt hear it, unless in 2wd
but again..i could be worng..might not be a cv at all:P...may be blown front diff...but i doubt that
dave
dave
slippery diff? i might mean open diff dave, I don't think he has an STI gearbox with front lsd
i know what i mean andrew...u just need to think aobut it...lol..slippery diff...open diff...same shit different day:P
Agreed with the above.D3V1L wrote:because in fwd its trying to drive the front wheels.....slippery diff means drive goes to blown joint = noise
