urgenent help(bullbar)
does anyone have any solutions to broken spot welded nuts down the chasis rails were the bullbars connect on brumby the wrap around type bars
cheers
camo
cheers
camo
- Suby Wan Kenobi
I believe you can hold you tongue right with a suitable spanner, i would off you a hand but i am going down the sunny coast on friday morning and madly backing.. etc. If you get stuck and can wait until Tuesday i might be able to give you a hand then.
"Claudia"
"Claudia"
I had same problem - two welded nuts broke off inside the chassis rail & were about 25cm from open end. I used a lot of magic words & made reference to the fact that the parents of my Brumby never were married.........then I put a loop of ribbon (like used for a present) through the bolt hole, stuck a bent coat hanger down the chassis rail & pulled out the ribbon (holding the other end of the ribbon of course) . I tied the ribbon around the thread of a high tensile bolt (with washer already in place ) and pulled the bolt down the chassis rail with the ribbon .... & out popped the thread through the bolt hole. So it was easy to put a washer & nut on the thread & tighten it up (I needed multigrip to hold one of them)
One day , when the car is wrecked, I hope the wrecker looks at it & wonders how anyone put a bolt so far down inside the chassis rail.
