Just trying to sort out an imbalance in a brumby tailshaft..(ea82T with 5speed box)
What I know- Rear axles have just been serviced...problem not there
Diff is good....problem not there
Ran the car without the tailshaft (Stuffed rag in rear of gearbox housing...ran sweet..
So problem is in the tailshaft.
Tailshaft is in good order manufactured by company at Toombul; Brisbane
No marks, scrapes, dints and universals all good.....BUT
it has a grease nipple on each uni and they are set at 90 degrees to each other instead of 180 degrees. I have the tailshaft on my workbench.
Question:- would you expect the weight of the two grease nipples to send a significant vibration through the car enough to be noticable and massage your back????
I am going to change one over so that it is opposite the other (180deg) and see what happens...
Anyone had this sort of problem before?????
