EA82T bad idle
chriSTIan
EA82T bad idle
Post by chriSTIan » Tue Jul 29, 2008 7:46 pm
Hi all
Just finished a rebuild on a mates rx turbo,we replaced the rings,recond the heads,new belts,plugs,fuel filter,seals and gaskets etc..
The car runs fine once on boost but at idle it hunts and stalls.
When the car was bought it never ran properly we then found out that there was an air leak at the inlet manifold gasket.
Just want to know if the injectors weren't spraying properly if it could be the cause,what about a dodgy air flow meter?
Thanx for your input
Chris
Post by steptoe » Tue Jul 29, 2008 8:04 pm
or the hose that carries air through the fast idle thing under the thermostat and into the inlet plenum about 75mm long 12.8mm ID ?
What sort of AFM ? flapper or hotwire ?
standard RX EA82T or vortex style with (4 legged) spider manifold ?
and someone is gonna ask about timing belts install procedure.....
chriSTIan
Post by chriSTIan » Wed Jul 30, 2008 8:46 am
Will have 2 check for the size of the hose,flapper afm,rx engine.
Timing belt done by Paul from RSR
Post by steptoe » Wed Jul 30, 2008 11:16 pm
also , the seals that each injector sits on in the manifold - seen them stuffed causing diagnostic chaos in a Falcon
