Right headlight extremely dull.
Posted: Tue Jul 15, 2008 10:48 am
by subarooster
heeya, The other day i hooked up spotlights and everything was sweet... but the next day, my right headlight is extremely dull. the power going to it is 0.70 volts on low beam and 10.00 volts on high beam.... Very strange indeed. Since this happened i have pulled out the spotlights and wiring but it is still dull. I have a bad feeling that i've killed something in my poor attept of wiring up spotties. Does anyone have an idea what has happened without actually seeing it? cheers, Tom
Posted: Tue Jul 15, 2008 11:08 am
by BrennyV
check ur fuses
Posted: Tue Jul 15, 2008 1:02 pm
by subarooster
haha u were right. I usually would check the fuses but i figured that theres power still going thru so i didn't bother? is there a reason that it was still working but very poorly?
Posted: Tue Jul 15, 2008 1:03 pm
by BrennyV
not 100% its just happened to me before also when playing with spotties.
Posted: Tue Jul 15, 2008 2:04 pm
by chubby37
just got told that jcar sell glow fuses...when they are faulty they let off a glow so you can see whats what without having to pull them out one by one....about 80cents each i think
Posted: Tue Jul 15, 2008 5:09 pm
by Gannon
Could be a backfeed from the relay you had hooked up.
If you are still having probelms, i'll be out that way on the weekend so i'll have a look then
Posted: Tue Jul 15, 2008 5:58 pm
by subarooster
all fixed now
very happy and would never of thought to check the fuses. thanks heaps!
Posted: Fri Jul 25, 2008 9:26 pm
by rob83ke70
I got very confused with the first one I encountered so don't feel too bad. There is a separate fuse for LH and RH headlamps, when a fuse blows, the headlamp goes really dull. I've encountered a few more since. Headlamp bulbs in upside down seems to happen a bit too....
