EA82T fuel filter
Posted: Wed Jun 25, 2008 7:00 pm
by LTurbo
Car is running like crap so just going along ruling problems out, I am going to change the fuel filter as I never have yet in this car.
At the moment it does not have a standard suby filter, looks like a commodore one (out of a VL?). Anyone ever heard of this? Think of a reason for it? Cheaper? More flow?
Also anyone know if the EA82 and EA82T filters are the same?
Posted: Wed Jun 25, 2008 7:06 pm
by Subafury
i put a commodore one in mine too, coz it was cheaper. had no probs.
Posted: Wed Jun 25, 2008 7:11 pm
by LTurbo
Subafury wrote:i put a commodore one in mine too, coz it was cheaper. had no probs.
Do you remeber what type of commodore it was off?
Posted: Wed Jun 25, 2008 7:15 pm
by Matatak
most of them are pretty much the same from wt ive seen. VN thru VT or later
just ask for like VN 6 cylinder.
Posted: Wed Jun 25, 2008 7:42 pm
by Gannon
I just got a universal EFI (make sure its EFI) fuel filter from Super Cheap.
Posted: Wed Jun 25, 2008 9:27 pm
by timmo
Ryco z168 is what I use (VL 6 cyl i think)
Posted: Fri Jun 27, 2008 11:44 am
ring diamond guard in tuggeranong 1800 number, i got mine from them, a listing for subaru L series efi, no need to spec turbo
Posted: Sat Jun 28, 2008 5:50 pm
by LTurbo
Changed the filter for a with a commodore one again. Works a treat. But the car is still not running great. but I think it might just be down to the 10month old fuel in the tank now.
Posted: Sun Jun 29, 2008 10:21 am
Ya could be right. Modern day ULP does not seem to have a shelf life. A mate pulled a yammy 80 carby apart last week. As I arrived all i could smell was STALE petrol I thought was years old, but it had only been in since xmas.
So, does ya fuel have a really bad smell to it, more than usual?
Posted: Sun Jun 29, 2008 12:10 pm
by LTurbo
steptoe wrote:Ya could be right. Modern day ULP does not seem to have a shelf life. A mate pulled a yammy 80 carby apart last week. As I arrived all i could smell was STALE petrol I thought was years old, but it had only been in since xmas.
Smells probably a bit stronger than usual, but not sour really.
So what’s what the remedy for stale fuel? Just top the rest of the tank up with fresh fuel? Add some octane booster?
Posted: Sun Jun 29, 2008 9:03 pm
use it or remove it (keep, just in case its not the cause) and try fresh. The first 20 litres I used in my new Brumby engine [ea81 carb] rebuild pinged and carried on, didn't like to idle consistently. This cats piss had been around 18 months and six months and mixed. Ran it real low and filled it afresh and by the first 100km or so it ran fine and happy. Dunno why ??? just fresh fuel ??
Posted: Sun Jun 29, 2008 9:07 pm
Hows about using some more technical and descriptive terms ~ crap is so broad a term to use in here for dagnosis.
start up cold, start up hot, all temps, all loads, all speeds, or particular revs/load/speed boosting?? gear
Posted: Mon Jun 30, 2008 5:15 pm
by LTurbo
steptoe wrote:Hows about using some more technical and descriptive terms ~ crap is so broad a term to use in here for dagnosis.
Very lumpy at idle and running. All temps, all speeds. Worse under load, revs easily up its range when not under load although still rough. Very low on power when driving, struggles to reverse up driveway. Surges when cruising along and not under much load, slight surges at idle as well.
I reckon one cylinder is not firing and the injectors are my next suspect.
Posted: Mon Jun 30, 2008 5:31 pm
by Gannon
INJECTORS!!
I had a spare set laying around so i went and got them serviced/cleaned/flowed and then swapped them into my car this weekend.
Idles heaps smoother, low speed driving around town is smoother too. But the biggest difference i discovered, it pulls all the way to 6k with no hesitation at all.
(i had a stumble at 3k and it wouldnt pull past 5 before i replaced them)
Also, if you think your fuel pressure regulator is not working, get one for an N13 Pulsar or a JD/JE Camira (they are the same BOSCH part no.) It is practically the same as the Subaru one, but can be found at your local parts supplier.
Posted: Tue Jul 01, 2008 9:19 am
and if not them, fuel pressure gauge T'eed in to the line and stuck to the windscreen for a test drive may show some ugly sign, but from my experence with this set up even a deaths door step pump can run nicely free revving, its only when the load comes in that it won't cope
Posted: Tue Jul 01, 2008 12:47 pm
by discopotato03
Tell me more about the fuel pressure regs as I am a wreckers rat and Camira's/N13's are grass seed common . A lot younger (well less miles) than your never say die L series donk/reg .
Cheers and thanks for the tip , A .
Posted: Tue Jul 01, 2008 11:09 pm
I priced new camira reg at Holden a year ago , about 130 bucks ~ thanks, but no thanks
Posted: Wed Jul 02, 2008 6:25 am
by Gannon
i paid $80 from injectacarb.com
I wouldnt bother with a fuel pressure regulator from the wreckers, its probably gonna be in the same condition as the one in the l series (rubber diaphragm lost its rubber-ness)
Posted: Fri Jul 04, 2008 10:29 am
Thomas, waddijado to fix your beast ?
Posted: Fri Jul 04, 2008 11:07 am
by LTurbo
steptoe wrote:Thomas, waddijado to fix your beast ?
I really did not want to pull the injectors out, so I went back and double checked all the simple stuff again. But this time I actually tested the spark leads, one was gone and possibly another as well. It was just the leads:oops: .
Fiddled with the idle, checked the timing, changed some fluids, and shes running sweet now.
