excessive fuel consumption... what else can i do?
- tassyraider
hi as previeous post said
how many kays on vehical
is there a sticker on or around the engine bay stateing when belts changed
i belive the belts to be changed aprox 70,000ks as they may be getting on or past the interval they will be streched and on occurances can jump teeth on cam wheels
its a pain in the arse job to check the bloody things but you are arsking Qs sorry for the inconveaneance
cheerz mick
cheerz mick
current ej18 awd targa brumby
95 impreza awd sportz wagon
Car has done 130000 odd k's. car has full history log book and cam was done at 98,000 i think from memory. i may check this, but im at a loss as to understanding how the car can be timed properly when the belt has jumped?tassyraider wrote:hi as previeous post said
cheerz mick
- tassyraider
Its easy to time the spark with the crank, you twist the distributor in which ever direction...92subbie wrote:Car has done 130000 odd k's. car has full history log book and cam was done at 98,000 i think from memory. i may check this, but im at a loss as to understanding how the car can be timed properly when the belt has jumped?
But the valve timing is in the belts and how they relate to the crank, to time these you have to take the cam covers off and check that each side is lined up properly, if not, fix it or replace the belts and do it that way...
So if there is a tooth that has been skipped for what ever reason, someone may have re-aligned the spark to "make it right" when really there is another problem...
Make any sense to someone? I'm not sure that i've explained it the best i could... Its been one of those days...
yep that makes perfect sense! thanks for that! i am studying automotive engineering so i have a reasonable idea of how engines work and stuff but sometimes its best to get someone to explain it in detail. thanks heaps and i will be sure to check it.
do you think this could make a huge difference though to fuel consump?
yeah thats what i thought. it does "splutter" when the foot goes down but i always thought that was the boxer engine noise, perhaps im wrong? it also pauses for a bit when looking for instance response when the foot goes down at low speeds, say between 2nd and third gear.jono wrote:wouldn't it run a bit off if a tooth had been jumped. You mentioned something not right other than fuel consumption ?
Any change in the valve timing (eg cam belt skipped a tooth) will have an effect on engine performance, unless you've got a stage 2,3 or whatever cam in there it probabily won't increase your performance...
How's it all going anyway? Notice the last msg was before i went a way for a bit...
hey
have given the idea of the cambelt skipping the flick, as i dont think this is the case. i have however had the cat checked by true flow exhaust at no expense (although it wasnt cut open to check 100% that its stuffed). they put it up on the hoist hit it a couple of good times and it didnt rattle. then we put it down and checked the flow out of the exhaust. now this is something i have never thought of doing and have only felt the flow at idle. at idle the flow is good and you can feel good pressure when you put your hand close. however, when you rev it up to say about 2,500rpm the flow gets significantly less!! this was weird...
the bloke at the exhaust shop had never experienced this before and he said that he bet his left nut on it being a stuffed cat! haha! so yeah we went and checked the price of a new cat and installed it was going to be 550... i was startled some what! but i know of someone who may be able to get me one for 400 or less so ill be putting one in myself.
what are your thoughts on all this guys?
92subbie
Get a "striaght" through cat, but don't mention anything sports, this adds near 40% onto the price instantly.
Other method is to crush the inners of the cat and shake them out. My car did this itself when 4wd'n, it rattled for a bit so i took it off and shook out the crap. All good now.
Other than that, replace it or get someone to do it for you.
is there different sorts of cats you can get? like i mean can i get a "universal" one? is the genuine Subaru one (the one i was quoted for) include from the headers all the way to the next join after the cat? or is it just for the cat itself and i would need to weld it in no matter what cat i get?
whats the go with these "straight" through cats El_Freddo?
Unless you need it to last you until your next lifetime there is little need to go genuine, just after market at your local exhaust shop - if they are available. The genuine original is a one pice y pipe from heads to beyond cat to mid pipe as would the after market one too I would expect. The straight thru cat may be just an emergency/diagnostic fix but not legal. It is simply a case of bashing the insides out of the cat where it sounds to be blocked. If this then sorts your problem you go buy new to remain legal and non polluting.
About the non-polluting part. This is only if you're replacing your cat every two years, after that they are no good from what i've read.steptoe wrote:If this then sorts your problem you go buy new to remain legal and non polluting.
A straight through cat apparently still works like a regular cat, costs more but is much more free flowing than a standard factory unit. This is what i was recommended for future exhaust ideas. I dunno if you can get one but i've heard its a sports job.
The cat on my car is hollow now, i was 4wd'n one day and hit it on a rock, it rattled from then on for a week and the car ran like sh!t, after that it was fine and seemed to run better. Sounds tinny now though, i've hit another rock at some stage and its got a good mark in it now...
- Suby Wan Kenobi
