not quite a direct plug and play, it will take into account pretty much all of talasas's mods and just roll it into a single relay. Abit of joining/splitting of wires is required.El_Freddo wrote:Nice find!
Or do what Talasas did. That unit above looks a lot neater though and I would presume that it is a direct plug and play?
should be an interesting day on sunday when i go investigate the car.
first thing i will be checking the timing, hopefully i can just visibly do this by removing the end timing belt covers? (making sure the lines on the belt line up with the marks on the covers, NOT the cogs?)
if thats all fine, i'll do the relay mod and if that doesnt fix it, i think the only other thing it can be is the fuel pump/injectors.
geez its turning into a mission!
so far ive replaced(in the past week or so)
-new drive belts (needed to be done, i realise its got nothing to do with the issue)
-new plugs
-new coil
-new fuel filter
-new starter motor (unrelated problem)
starting to remember why i bought newer cars with no problems! haha
