Starting issue - auto outback
Post by Alex » Thu Aug 07, 2008 11:55 am
holla for a marshall!
Or an intimidator! :d
Post by D3V1L » Thu Aug 07, 2008 11:59 am
FROG wrote:try them out for warranty anyway most batteries are date stamped, be worth a go anyway
good luck Dave
i would, but i bought the battery in kalgoorlie, for a super duper special deal through my company with westrack, and the battery has no stamp nothing on it, and because its not used for work purposes i could get into trouble..hehehe if thy find out i put it in my car..lol
dave
FROG
Post by FROG » Thu Aug 07, 2008 12:07 pm
ahh well then maybe not lol
cant swop it out into another work vehicle
btw what is it ?
just out of interest
Post by D3V1L » Thu Aug 07, 2008 12:19 pm
990 cold cranking amp, specifically for westrac, so its catapillar, for all their smaller tractors and trucks, after days of deliberation this is what we decided would be best for my setup.
obviously not ..lol
dave
Captain Obvious
Post by Captain Obvious » Thu Aug 07, 2008 4:35 pm
need 2 people for this, but put a multi meter on the solenoid terminal for the starter but leave the wire connected and measure the voltage, if there is low volts there say 6 that your problem, its not pulling the contacts on far enough, mine has/was doing the same thing, you can do a patch by adding a relay.
use the starter wire to activate the relay and run a feed from the battery to the starter.
bryan
Post by D3V1L » Thu Aug 07, 2008 4:37 pm
captain, this is exactly the problem i was having...and i have done exactly what u have just explained:), the starter motor problem has now been solved its now just my dicky battery which im displeased about but im obviously gonna have to fix it regardless
cheers
dave
stamp_licker
Post by stamp_licker » Thu Aug 07, 2008 6:18 pm
dud batteries happen.I brought a battery once and it wouldn't hold volts so i rang the mob i brought it off ,said they were new owners.So i rang the manufacturer and they said the battery was 2 years old and had been sitting on the shelf.Doesn't help you much though.
Hope you get it sorted.
Building a hardcore postie:D
vincentvega
Post by vincentvega » Thu Aug 07, 2008 7:07 pm
under 14V is a float charge. 14.2 - 14.4 is a boost charge.
you boost charge in a car application.
Matatak
Post by Matatak » Thu Aug 07, 2008 7:08 pm
AndrewT wrote:But you're using an EA starter yes? Because of the adaptor plate and EA gearbox?
if i was talking about my MY yes....
but thinking about it i dunno if he has heard my Lib start. altho i did take it to the pines that time
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
SuBaRiNo
Post by SuBaRiNo » Thu Aug 07, 2008 7:26 pm
Im not gonna sift through all the stuff in this thread Dave... Call me if your still having dramas. You should have called me in the first place... doofus. :)
Dave
Post by Subafury » Thu Aug 07, 2008 8:42 pm
what if you do the sneaky sneaky and swap it into one of the work vehicles, then claim a new one for that thru work, and swap the new one ;)
seagull
Post by seagull » Thu Aug 07, 2008 8:49 pm
Fit a relay to the solinoid on the stater , Dave will know how to this I would say
+ I wonder if it got water in it ( ? )
Post by D3V1L » Fri Aug 15, 2008 12:48 am
issue resolved
thought i fixed it
turned out the alternator was charging at idle, but not when revving
vincentvega
Post by vincentvega » Fri Aug 15, 2008 1:00 am
hate to say it - told you so :P
good to hear its sorted.
Post by D3V1L » Fri Aug 15, 2008 5:10 pm
i found out the hard way at work
1.5 tonnes of water tank on trailer,,, middle of boggy sand, 200 odd metres from nearest hard road
turned car off
never started back up :P
and like i said..it was charging at idle. it was even chargins at 2000 revs,,, anything HIGHER and it was not charging...was draining battery, and according to the subaru workshop i went to today, they put it on an analysis machine....and said up untill 2000 revs it was charging to proper capacity, but faster it span, the bushes slowly detatched from the centre bit
dave
Post by Subafury » Sat Aug 16, 2008 11:01 am
so when does she get a new alt?
Post by El_Freddo » Sun Aug 17, 2008 1:35 am
So how did you find this out?
And what's the fix - a new alternator?
Post by D3V1L » Sun Aug 17, 2008 7:09 pm
the fix is sweet **** all atm....really
dave
Post by Alex » Sun Aug 17, 2008 10:44 pm
the fix is alex's spare alternator! lol.
Post by D3V1L » Sun Aug 17, 2008 10:55 pm
untill i find the energy to get mine rebuilt or a new one, alex spare isnt a very good alternative caus its different..but will do to get me to work and back
dave
