Right headlight extremely dull.
subarooster
Post by subarooster » Tue Jul 15, 2008 10:48 am
heeya, The other day i hooked up spotlights and everything was sweet... but the next day, my right headlight is extremely dull. the power going to it is 0.70 volts on low beam and 10.00 volts on high beam.... Very strange indeed. Since this happened i have pulled out the spotlights and wiring but it is still dull. I have a bad feeling that i've killed something in my poor attept of wiring up spotties. Does anyone have an idea what has happened without actually seeing it? cheers, Tom
BrennyV
Post by BrennyV » Tue Jul 15, 2008 11:08 am
check ur fuses
Hunter S. Thompson
subarooster
Post by subarooster » Tue Jul 15, 2008 1:02 pm
haha u were right. I usually would check the fuses but i figured that theres power still going thru so i didn't bother? is there a reason that it was still working but very poorly?
BrennyV
Post by BrennyV » Tue Jul 15, 2008 1:03 pm
not 100% its just happened to me before also when playing with spotties.
Hunter S. Thompson
chubby37
Post by chubby37 » Tue Jul 15, 2008 2:04 pm
just got told that jcar sell glow fuses...when they are faulty they let off a glow so you can see whats what without having to pull them out one by one....about 80cents each i think
Post by Gannon » Tue Jul 15, 2008 5:09 pm
Could be a backfeed from the relay you had hooked up.
If you are still having probelms, i'll be out that way on the weekend so i'll have a look then
subarooster
Post by subarooster » Tue Jul 15, 2008 5:58 pm
all fixed now :) very happy and would never of thought to check the fuses. thanks heaps!
rob83ke70
Post by rob83ke70 » Fri Jul 25, 2008 9:26 pm
I got very confused with the first one I encountered so don't feel too bad. There is a separate fuse for LH and RH headlamps, when a fuse blows, the headlamp goes really dull. I've encountered a few more since. Headlamp bulbs in upside down seems to happen a bit too....
Return to “Trouble Shooting”
