Exhaust Gasket and Stud Replacement
G'day all,
after the weekend ive been left with no gasket or studs on one of my exhaust to engine pipes.
having not replaced one before is there anything to look out for? is it just a case of putting in new studs and gasket, will i need any sealent or the like.
Cheers Tim
Cheers Tim
Why is there no studs?
Sometimes the studs can act like bolts when the nut is rusted onto them. This could be good because they may have vibrated loose.
If they didn't vibrate loose you may have hit something & stripped them in which case you will need to retap for new studs.
The other thing that can happen is that they sheered off. This is a real pain because you will need to use something like an e-z-out to remove them. I have always had troubles using them.
Why are there no studs?
The gaskets look like they are made from the same material as most manifold gaskets, in which case they should seal ok. I have heard a lot of Suba's with leaky exhaust gaskets so other people may have more informed ideas.
Guest
- stamp_licker
