Front Brakes - what am I doing wrong?
- twilightprotege
I'm replacing the rotors and pads on my 87 RX and no matter what i try I cant push the piston on the front caliper back to allow for room for the new pads to fit over the rotor. Tried everything i can think of, plenty of force, D-clamp and all. Am I missing some trick that I dont know about? Rears were no problem (pushed back by hand), just cant move the front. Would it be something to do with the hill assist thing? Help!
I have an idea that these do not simply "push in". You actually need to "screw" them in. I seem to remember that there are some cutouts which fit the factory tool and which simply winds them in.
Someone please correct me if I'm wrong.
Dave Hill
MY13 Outback - The new blue one.
MY99 Outback - As it's maker intended - but with a fresher engine now.
1994 RS Turbo - Not quite so stock! And freshly repainted now![Smile :)](./images/smilies/icon_smile.gif)
And then there's the family Vortex - rebuilt, updated and now unregistered and gathering dust in the shed.![Very Happy :D](./images/smilies/icon_biggrin.gif)
Yep thats correct you actually need to screw it in, there is a notch on the piston, all you need pliers and turn it clockwise until it reaches to the end... if you're screwing it "out" then you're going wrong way (fluid will leak!)
With rear disc is to be pressed in with clamp.
For Liberty above is different, front is push in and rear is same as front.
![Image](http://i14.photobucket.com/albums/a313/tmerritt/PICT0927.jpg)
If you loosen the bleeder - you will need to bleed whole system.PeeJay wrote:My series are screw in, can't remember about the L series, I don't think they were. I've found undoing the bleeder nut a tiny bit help alot.
- twilightprotege
figured it would be something easy. will give it a bash tomorrow night. i tried losening the bleeder and that didnt work either (bleeding the whole system anyway). so strange that they push out but require screwing in. i assume it's something to do with the handbrake being on the front wheels. anyway, thanks guys.
Yeah they definitely need to be screwed back, that got me the first time too.
I believe they actually gradually unscrew rather than just push out as you slowly wear the pads down.
EZ30 L series - Monsterwagon
- twilightprotege
Ah my mistake. Subaru mystical witchcraft then ![Smile :)](./images/smilies/icon_smile.gif)
Thats exactly the reason why you need to screw them in. It got me the first (and last) time I swapped the front pads. I still need to get a new rubber boot for one of the calipers cos I pinched ittwilightprotege wrote:so strange that they push out but require screwing in. i assume it's something to do with the handbrake being on the front wheels. anyway, thanks guys.
![Confused :???:](./images/smilies/icon_confused.gif)
You'll know for next time
![Wink ;)](./images/smilies/icon_e_wink.gif)
ditto had me stumped I read the service book three times then figured it out and I used a pair of needle nose pliers in the indentations. But I take it these things have something to do with the front park brake.
87 targa brumby (Neglected),
+ others.
+ others.
- Reg Brumbys
Yep got me to the first time - very frustrating until I figured out what it was. Next time I didn't touch the break pedal or the handbreak when I had the calliper off and it didn't move the piston and slipped straight back on.
![Image](http://www.ausubaru.com/coppermine/albums/userpics/normal_Sig%7E0.jpg)
"The Express"
Subaru Brumby 1990
2" B-Y-B LIFT (New)
Power Steering
14" Wheels with Maxxis Bravo MT-753's
Spotties
L-Series Interior Light
Roll Bar (to be added)
The piston is pushed out by pressure of the brake fluid when the brake pedal is pushed, it does not turn. The oring retracts the piston by virtue of its square profile and being twisted and springing back into shape after the pedal is released. The handbrake mechanism pushes the piston out by rotating a spiral gear in the guts of the piston and does not turn the piston either. Due to the handbrake levers limited stroke it relies on the piston being close to the pad, that is why you have to wind it back in, it stays out after the pedal is pushed.
In this respect it exactly the same as rear disc brake calipers on Falcons and Magnas and lots of other cars with the handbrake on the rear and rear disc brakes have been for years.
Suby Newbie
Suby Newbie
or jsut buy a tool.SUBYDAZZ wrote:If it won't wind in it might be stuffed.
To make a tool for the job get a 24mm or so socket and grind away two opposite sides down about 3-4mm leaving two tabs. Then you can slot the tabs into the slots on the piston and wind it in with a ratchet or breaker bar as required.
they have multifit ones prolly like 10 bucks
Wagon is no longer....
![Sad :(](./images/smilies/icon_e_sad.gif)
