EA 82 timing clikki-tikki
Saeble
Post by Saeble » Tue Apr 22, 2008 8:02 pm
My L series with 250+K clicks is making the classic timing clicking and ticking noise whilst running, mostly when cold. Am I right in thinking there's bugger all I can do about it ? I've not done heaps of mechanical work on Subies, my experience has been with older stuff mostly.
Battlewagon
Post by Battlewagon » Tue Apr 22, 2008 8:22 pm
Mine was the same, bit the bullet, replaced the lifters and no tickety tick.
Not a hard job either, just go slow and don't muck up your cam timing - mark everything!
Post by Gannon » Tue Apr 22, 2008 8:35 pm
Yeah replace your lifters and the oil pump seal (known as the mickey mouse seal)
Whole set will set you back less than $400
Saeble
Post by Saeble » Tue Apr 22, 2008 9:22 pm
four hunnerd !?!
ouch, that's like 45% of the cost of the whole car.. :D
methinks it can keep ticking, till in stops... :)
the inner CV's are a higher priority anyway, heard the first clicks of death from them today. Speaking of which, where does one go to get CVs without being dry shafted in the process ?
Venom
Post by Venom » Tue Apr 22, 2008 11:06 pm
I'm pretty sure there's a thread on curing lifter noise somewhere in the forums. If its only done 250k i'd try a genuine oil filter and a slightly thicker oil. At the very least it won't hurt your car, and it might solve the problem. Thats what worked for me.
fredsub
Post by fredsub » Wed Apr 23, 2008 8:29 am
theres threads on using diesel oil to flush.....
If that doesn't work, just get a oil pump rebuild kit and seals,
esp if its done >250kkm, DIY < $100
maybe replace timing belts (as they have to come off)
I really doubt you have to replace the lifters though.
shuffbag
Post by shuffbag » Wed Apr 23, 2008 11:51 am
i would be looking straight at the oil pump seals, its about $35 for the kit and in some case's thats all that required.
Return to “Trouble Shooting”
