EA82 turbo hesitation
Ok here it is the problem:
Under full throttle or partial throttle, engine feels like it is hesitating or misfiring at 2800-3200 rpm, below or higher than this range it runs perfect.
What I have done:
Checked operation/cleaned connections for:
Thermosensor (coolant temp sensor)
Oxygen sensor
EGR solenoid/Egr valve
AFM
Ignition timing
Turbo plumbing
Vacuum hoses (all)
Replaced:
Plugs
Wires
Cap
rotor
Fuel filter
Things I havent tried/changed:
Coil
What else?????
This problem is driving me nuts, somebody give me a helping hand!
What I have done:
Oxygen sensor
AFM
Ignition timing
Turbo plumbing
Vacuum hoses (all)
Replaced:
Plugs
Wires
Cap
rotor
Fuel filter
Coil
What else?????
I second fuel pressure, i had a very similar problem where it would stumble at 3100 rpm
