Possible blown head gasket ej20g
ok,
this engine is driving me nuts, just as i had got everything working perfectly, the engine started to misfire when under heavy load, such as offboost in 2nd doing 2000 revs. The next time i took it out it got worse, misfiring and backfiring and making for a very jerky ride off boost.
I started it up this morning and to my horror a shitload of white smoke started coming out of the exhaust, when revved it made quite a cloud. i let it get to operating temperature which took about 6-10 mins, and it was still doing it. I took it for a drive anyway and as soon as i did, all the smoke stopped, but it wasnt running quite right, felt like it was lacking power.
We suspected a head gasket had blown so i checked the oil, looked fine, checked the coolant, and when i rev the engine quite a few bubbles appear at the filler cap.
What do you guys think?
cheers,
adam
cheers,
adam
L Series current mods:
EJ20G, 3" lift, Roo bar, spotties, EJ Sporty steering rack, desert rats, 27" tyres, 2.5" exhaust
good possibility
but i would check the awesome rs turbo ignition coils..they have a BIG habbit of screwing around wif u ....that could be one of the courses of the misfiring
as for the smoke...could be head gasket...go to a mechanic shop get them to do a monoxide test in the cooling system...that will determine if its leaking gas into the coolin system or not
dave
dave
bubbles is not at all good. run it with the radiator cap of and if a steady stream of bubbles keep coming it is a sad day.
									______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
Bubbles could just be more air bleeding out of the system....but definitely that's good advice to get a monoxide test done.
The RS coil packs are renown for causing problems, I'm having a very minor one with mine but certainly nothing as severe as what you've described.
EZ30 L series - Monsterwagon
alright,
Well today i went and saw matatak and we did a teekay test, that confirmed it was not the head gasket. Both matatak and brennyv came for a drive and the general consensus was that the coil packs are ******. so ill be up for a bosch coil conversion.
Which bosch coils do i use? There is a few out there, some to use with resistors and some without.
Cheers for the teekay test mat.
Adam
Adam
I gave Adam this link...explains about the coil conversion.
http://www.rextas.com/tech_coils.pdf
Latest developments:
Ok, Dave came around last night and it seems it is idling on 3 cylinders. Found out that no.4 is the cylinder that refuses to fire. Took the coil out and it was sparking nicely. That leaves 2 other things it could be, compression or fuel.
When we started it up, we saw fuel coming out of the exhaust pipe which means it obviously has fuel thats not getting burnt. That leaves the last of the 3, compression.
Today when i started it a lot more smoke than usual started coming out out of the exhaust, still not sure what type but it does look like steam. There is still a lot of bubbles coming up out of the resovoir tank when revved as well.
Will a compression test tell me for sure if its the head gasket?
Adam
Adam
do a compression test.
but it wont pinpoint what it is for you.
if its low on compression it culd be the piston rings or the valve seats.
culd also be other things like intake gasket or stupid shit like that whic leans the mixture out to much and wont fire.
but get a comp test first lol
Wagon is no longer....
u can borrow my tester if you want.
 VER7 STI  (FOR SALE) & RIP     EJ22 AWD LEONE
Hunter S. Thompson
Hunter S. Thompson
thanks brendan but ive got a compression tester, i did the dud cylinder and its up there at 151 psi, the same as the cylinder beside it. i have yet to do the other 2 cylinders on the opposite side, will do that tonight. looks like an injector has gone bad again on n0.4.
Adam
									Adam
hey mat,
Nah i never changed the fuel filter on it, used the original from the cut. Ive just finished testing all cylinders, they are all exactly the same at 151 psi.
all the spark plugs looked the same and normal except for the one that wasnt firing, looked a lot blacker than the rest.
Adam
Adam
black plug was not firing at all when i saw it
dave
									dave
i just finsihed doing the coil conversion tonight, and it made it worse. now it doesnt even want to misfire on that dud cylinder anymore, running on 3 all the time now. whats going on, im so confused.
cheers,
adam
									cheers,
adam
Look further into the stuck valve possibility, I'd make a post on rslibertyclub.org for advice...
