check engine light on 98 outback
dirty skirt
Post by dirty skirt » Sat Feb 09, 2008 11:17 am
the check engine light is coming on when when the engine is cold and stays on 4 a bit then goes out im guessing its got something to do with the temp sensor but what i want to know is can i get the code out by bridging wires at the connection where you put the hand held computer plug?if so what pins are they a diagram would be nice if someone has got one and list of what the numbers are to what code it is
thanks heaps guys i know someone will be able to help me
steve
Post by AndrewT » Sat Feb 09, 2008 7:36 pm
Is your Outback running the standard ECU? You say you have a hand controller so I'm guessing it's some kind of aftermarket ECU then??
If it is the standard one then there should be two black connectors near where the ECU is. If you connect them together then turn the ignition on, the check engine light should start flashing.
Count the number of long flashes (example - 3), and the number of short flashes (example - 4). This would be a code of 34. (I think I've got short and long round the right way!).
Theres a listing on the forum somewhere of what each code means - search is your friend.
madmat
Post by madmat » Sat Feb 09, 2008 8:37 pm
Frog did the post for the codes
______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Feb 09, 2008 8:44 pm
For the model of your car the plugs you are looking for should be in the divers side footwell near the heater
The long road ahead
dirty skirt
Post by dirty skirt » Sat Feb 09, 2008 9:17 pm
cool thanks guys and yeah andrew its a standard ecu i was talkind about the standard one that the subaru dealership use,can someone point me in the direction of the post of the codes for the ej25 outback 98 model
thanks guys steve
dirty skirt
Post by dirty skirt » Sun Feb 10, 2008 1:34 pm
hey guys i cant find the post about the codes, the code is 21 so if someone knows what it is can you let me know
thanks steve
Matatak
Post by Matatak » Sun Feb 10, 2008 3:19 pm
code 21 is the Coolant Temperature Sensor.
wont affect to much with the running of the car. but may or may not be telling the ECU the engine is always cold and slightly increasing the fuel consumption.
(id like someone to confirm if it does aswell coz ive been wondering if it will infact do that when theyre disconnected.)
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
dirty skirt
Post by dirty skirt » Sun Feb 10, 2008 4:45 pm
cheers matatak,at least i know its nothing drastic the light only stays on for about a minute so thanks for the info
steve
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Feb 10, 2008 6:59 pm
If your engine temp sensor fails it will have a fairly healthy need for fuel and once in normal running temp range can be difficult to start again and run smooth
The long road ahead
SUBYDAZZ
Post by SUBYDAZZ » Mon Feb 11, 2008 9:24 am
Sensor need cleaning / able to be cleaned? Where is , please remind me - in the radiator on under the manifold? ;)
SUBYDAZZ
FROG
Post by FROG » Tue Feb 12, 2008 1:52 pm
Diagnostic Trouble Codes - 1992
Subaru
11 Crank Angle Sensor (No Reference Pulse).
12 Ignition Switch.
13 Cam Angle Sensor.
14 Injector 1.
15 Injector 2.
16 Injector 3.
17 Injector 4.
21 Engine Coolant Temperature Sensor.
22 Knock Sensor.
23 Air Flow Sensor.
24 Air Control Valve.
31 Throttle Sensor.
32 O2 Sensor.
33 Vehicle Speed Sensor.
35 Canister Purge Control Solenoid.
41 Air / Fuel Learning Control Function.
42 Idle Switch.
45 Atmospheric Pressure Sensor.
49 Air Flow Sensor.
51 Inhibitor Switch (A/T).
51 Neutral Switch (M/T).
52 Parking Switch (A/T).
Return to “Trouble Shooting”
