1989 tps what does it do
i have 1989 touring wagon with mpfi motor just wondering what the tps does
my car was surging going down the highway so checked fault codes and found that they all lead to the t.p.s (throttle position sensor) now what i have done is disconected the unit (t.p.s) and am now driving the car around the car have been for about 2 months and am now getting bet fuel econmy than before is not lacking in power at all so my my my long winded question is what does this unit do or what is it supposed to do thanku for any reply
I used to run ea82t with microtech.It initially was set up with no TPS at all. So the fuel injector timing based purely on load via MAP sensor.
But either MAP has a bit of lag in, or there are some inconsistencies with the load or whatever.
With fuel injector timing based on a composite of MAP and TPS, you can adjust some points of the map where the TPS setting gets through better giving much better overall response, that and I think it then detects WOT more reliably, when in acceleration.
It also possible to zero all the MAP setting and run purely on TPS, but its very
edgy type of driving then.
I think my best approach to setting the map is to use MAP settings to achieve efficient fuel running,cruise, so not terribly good at acceleration,and then start adding TPS setting to do the acceleration bit.
So with this bit of story I hope you see what the TPS is for IMO.
The TPS is mainly for the Spark map, (85-86 models didnt have ECU controlled spark and thus didnt need a variableTPS) The TPS also improves drivability and economy.
The fuel map is a product of air flow and engine RPM, the other sensors, TPS, o2 sensor, temp sensors ect. simply fine tune it.
It wont have an enrichment while the throttle is in motion like an acell pump on a carby. Basicly as the throttle opens the manifold vacum drops off and air flow speed slows down for the brief moment so the cylinders lean out while throttle (without enrichment) is opened.
So many optioins not enough time or money
- littlewhiteute
