engine problem with 91 brumby
urabus_858
Post by urabus_858 » Wed Oct 31, 2007 8:11 pm
Hi im haveing a little problem with my engine atm (ea81) its been siting in my shed for about a month now because im rebuilding it. i tryed to start it the other day but all it would do is just click and wouldent try to turn over, so i checked the battery and the starter they seem to be ok because i tested them on my other car and it dosent seem to be siezed. any help would be
greatly appreciated
Matatak
Post by Matatak » Wed Oct 31, 2007 8:19 pm
can u turn the crank with a socket and bar?
does sound like a flat battery tho or one without enough charge to turn the motor after the oil had basically drained outta it.
i need to ask but do u no wt ur doin with a rebuild?
when u put pistons back in did u oil up the bore to elt them slide mroe freely.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
urabus_858
Post by urabus_858 » Wed Oct 31, 2007 8:27 pm
ohh im not rebuilding the engine sorry i ment it been sitting there while i have been repainting it and doing body work. i thought it was a flat battery at first aswell but it work fine in my leone. it was working fine the last time i started it so i dont know what the problrm is :(
Post by Alex » Wed Oct 31, 2007 8:36 pm
double check all battery connections are tight. grab a multimeter and see what the battery is putting out. It really does sound like a flat battery (or a crap connection)
Matatak
Post by Matatak » Wed Oct 31, 2007 9:04 pm
urabus_858 wrote:ohh im not rebuilding the engine sorry i ment it been sitting there while i have been repainting it and doing body work. i thought it was a flat battery at first aswell but it work fine in my leone. it was working fine the last time i started it so i dont know what the problrm is :(
ahhh i see now :D
yep check the battery terminals are tight
if not put a multimeter across the battery out of the vehicle and see wt voltage it has.
shuld be round 12.6 to start a car any lower and it wont.
how long since its been started?
Suba
Post by Suba » Wed Oct 31, 2007 9:12 pm
Matatak wrote: how long since its been started?
Mike.
Matatak
Post by Matatak » Wed Oct 31, 2007 9:37 pm
Suba wrote::)
Mike.
:oops:
thanx mike :)
check that the cables havent started coming outta the terminals aswell. even if the terminals are tight on the battery posts it may still not get much current if the wires are coming out. (mine did that once when i went to go to work ages back lol)
Post by El_Freddo » Thu Nov 01, 2007 2:17 pm
I'd be checking the spark plugs and fluid levels just as a precaution - make sure non of the spark plugs have coolant on them - worst case senario would be that a cyclinder has filled with coolant from a dodgy head or inlet gasket and is hydrolicing, making it near impossible for the starter to turn the motor over once the piston is trying to compress the fluid...
This is way out there and i'm hoping its not the case, you have tried the trick matatak has suggested with a socket and bar to turn the engine over by hand (with ignition off)?
If the engine turns over with no problem maybe try tow starting it.
90brumby
Post by 90brumby » Thu Nov 01, 2007 10:44 pm
try jump startin it seams the easyest thing to me
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Matatak
Post by Matatak » Thu Nov 01, 2007 10:46 pm
he needs to get back to us first :p
how goes it?
Post by D3V1L » Thu Nov 01, 2007 10:50 pm
sarter solonoid
l series did it to me once
Post by El_Freddo » Fri Nov 02, 2007 11:17 am
D3V1L wrote:sarter solonoid
Yeah that sounds the go. If this is it, hit the starter with a hammer gently on the solenoid (little cylinder bit with the battery wire and other wires hanging off it), this may make it un-stuck enough to throw out and engage with the fly wheel...
urabus_858
Post by urabus_858 » Fri Nov 02, 2007 3:30 pm
i will check that tonight, its hard trying to find time to have a good look at it atm.
Quote:
Originally Posted by D3V1L
sarter solonoid
i have tryed that i even took it out and put it in my leone and it worked perfectly.
thanks for all the ideas ill keep checking.
Xtreme_RX
Post by Xtreme_RX » Fri Nov 02, 2007 3:40 pm
Check you ignition switch on the steering column.......
http://www.subiparts.com.au
0438 887 746
Busdriver
Post by Busdriver » Fri Nov 02, 2007 4:14 pm
have you checked the terminals on the solenoid? what about testing the voltage at the starter motor, any huge drop when cranking could be the battery (needs more than 9 volts to spin it over quick) or the starter motor could be "poling" try your Leone starter on the beast?Tryed spinning it over on the starter without the spark plugs fitted? this would tell you if it is Hydraulic locking with coolant as the coolant should come out the plug hole under pressure.
Suby Newbie
urabus_858
Post by urabus_858 » Sun Nov 04, 2007 6:47 pm
Thankyou u everyone i fixed the beast i replaced the battery cables with new ones and now it starts, must of been a bad earth or the wireing was shot anyway thx again.
Return to “Trouble Shooting”
