wheel bearings in a 86 tourer
batesy
Post by batesy » Sun Jul 29, 2007 5:01 pm
gday, wonderin how to get bearings out of front assembly.... i have removed the front caliper, and disk, but cannot figure out how to remove the bearings.... do i have to take the drive shaft out???? this is the only way i can see of removing them
any help much appreciated thacks
Matatak
Post by Matatak » Sun Jul 29, 2007 5:14 pm
take driveshaft out and remover the hub from teh car - may not need to remove driveshaft jsut undo nut and knock it back so it is loose in the slot
also take steering off, balljoints and unbolt strut maybe
arent they built into the hub? so they will need to be pressed out??
dont qoute me on this as i dotn got an Lseries and cant remember wt i did to get mine out of my MY when i took it off
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AlpineRaven » Sun Jul 29, 2007 5:31 pm
They will require to press them out with an bearing press - normally clutch/brakes places have them. If you are in Melbourne Western Subs - I can do them for you.
Matt
Post by Matt » Sun Jul 29, 2007 7:31 pm
You can do them with a punch and big hammer....
"Claudia"
Post by AlpineRaven » Sun Jul 29, 2007 7:39 pm
Matt wrote:You can do them with a punch and big hammer....
You can but what happens if you hit it offset and will jam it up and make it 3x harder to remove or install.
Matt
Post by Matt » Sun Jul 29, 2007 7:47 pm
You must have one big hammer... as long as you hit progressive around the edge it is fine, i have never had a problem. Thats my 2 cents worth anyway.
"Claudia"
Chris_Rogers
Post by Chris_Rogers » Sun Jul 29, 2007 9:00 pm
press out. hammer will stuff them. did that all ready with mine.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
batesy
Post by batesy » Sun Jul 29, 2007 9:05 pm
thanks guys, looks like its goin to the mechanics, as i dont have a press, thanks for the offer alpine raven, but its a bit far away.... cheers
thanks for the quik reply
Post by AndrewT » Tue Jul 31, 2007 11:01 am
If you stuffed it up using that method then you did it wrong.
Theres no problem using a hammer and punch, as already suggested you just need to do it progressively and take some care.
But naturally every home mechanic has to draw the line somewhere, if you aren't confident then it is definitely smarter to pay the money.
Return to “Trouble Shooting”
