tacho going wacko ea82
while driving the tacho will just go springing back and forth by about 1000rpm it is also effected when i flick the lights on or the thermo's any ideas would be much appreciated
- vincentvega
- Suby Wan Kenobi
- Wraith
alternator is toast, even tho its still putting out 14v
i have had this twice in different L's.
jumping tachos, flickering lights, stereo dropping in and out
both times fixed with alternator being replaced.
my 2cents
my 2cents
Destroy waves, NOT beaches.
1990 L Sportswagon (Mine)
1988 L Touringwagon (Hers)
1998 Liberty GX Wagon (Ours)
1987 L Touringwagon (SOLD!!)
1986 L Jap Import Turbo wagon (SOLD TO TIMMO!!)
1986 L RX Turbo wreck (SOLD TO TIMMO!!!)
could also be a bad ground between the dash and the chassis
Happened to me once - it turned out to be faulty regulator (after 2 days ignoring it it went up to 17volts as it went off the voltage gauge and checked out whoa so i disconnected it and run off battery to auto electrician's) - I cannot remember how much, it was about 4 yrs ago and wasn't Subaru but it shows similar symptoms.
Pinch one from wreckers
Is this a servicable item?jono wrote:Didn't someone suggest voltage regulator (think that is correct term) on back of the DASH. pull dash out and on the board top left is a yellow thingy all on its own
My low beams tend to do this little dimmer thing from time to time, sometimes i wonder if they're actually going to turn off and not come back on... fun times! Doesn't do it on highbeams either, only low beams.
had same problem with my first L-series post tacho dash conversion.
Everyone (mates, none of them auto-electrians) said after 10 seconds of careful consideration, 'bad earth' like they knew what they were talking about...
Put up with it for a while, hoping it would go away. It didn't
In the end, ran an earth lead from the instrutment cluster to car. Tacho problem fixed...'they' were right.
D'oh
D'oh
