Changing brake pads on Vortex
Vortex75
Post by Vortex75 » Fri Jan 16, 2015 7:39 am
Hey guys, does anyone one know what the special tool is called that you use to wind the piston back in to the calliper?
Canny
Willy Fisterbottom
Post by Willy Fisterbottom » Fri Jan 16, 2015 8:29 am
I can't remember the name but Repco sell a multifit one fror around $15, I bought one last year.
Willy Fisterbottom
Post by Willy Fisterbottom » Fri Jan 16, 2015 8:33 am
This is it.
Post by steptoe » Fri Jan 16, 2015 1:13 pm
and there is a different one to Willys depicted tool.
Picture a socket say a 32mm one, half inch drive, and has had the 32mm open end cut down to leave two castellation like bits that lock in and allow you to rotate the piston so you can wind it back. Turn in a clockwise direction.
Post by El_Freddo » Fri Jan 23, 2015 10:10 pm
I use a pair of pliers to do mine.
Have since got the same as Willy above, but am yet to actually use it...
Bennie.
Post by RSR 555 » Tue May 05, 2015 10:22 pm
El_Freddo wrote:I use a pair of pliers to do mine.
I've been using a set of bullnose pliers since 1992 and never worried about buying a "special" tool as the plier method works perfectly :)
Return to “Trouble Shooting”
