Car goes left after making a left turn
1984 MY.
I noticed that the car would pull to the left after making a left turn, but go pretty much straight after making a right turn.
I checked the wheels for play, there was a little bit in one so I regreased the bearing and tightened the nut. That got rid of the play.
There was play in one of the inner tie rod ball joints, I replaced that. Still the car would pull left.
I went to a mechanic at a suspension shop and asked him. He checked everything and said he doesn't know, but if he was doing the job he would start by replacing the ball joints.
The ball joints were going bad so I replaced them, but it didn't help with the car pulling left.
Maybe it is the tops of the struts, but I don't know so I was wondering if anyone has had a similar problem or would know how to fix it.
- T.Farm.Brumby
Toonga's on it, steering rack would be my first check too.
Stock engine? Could be torque steer if you're running a more powerful engine than stock but that's far less likely.
If all else fails I'd be getting the front up on stands and running it to see what might be moving when it shouldn't.
Tom.
Tom.
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
castor.
Insufficient castor will cause a lack of self centreing. Perhaps you have hit a large pothole or obstacle on that side. A wheel alignment will show it, but still check for worn parts as previously suggested.
Thanks for all the advice.
All the rubbers are in good order, they are urethane except for the LCA ones which the mechanic also looked at and said it was good. I replaced the ball joints on the LCAs.
There is no noticable play in the steering rack, could there still be a problem with it?
It has had a wheel alignment since and it didn't make any difference, but maybe I will try a different place and see what they say. The place I went to didn't seem to know much about the car as they were confused why there was positive camber on the front wheels.
I know it isn't torque steer because it will persistantly pull slightly left, even after hundreds of km, until a right turn is made.
There is one thing I forgot to mention before though. I had the car on the ground and got someone to steer it and I did notice that the springs were turning in their seats a bit. I am not sure if this is normal or not. I did tighten up the springs a few turns but it didn't make a difference.
steering pull
Your comment about pulling left until you make a r/h turn would appear to back Toonga's idea. The springs rotating could be an issue if the bottom of the coil is open ended. If it is flat like the top then it shouldn't alter ride height. If it is open ended it could ride up in the bottom saddle after a l/h turn , staying there until the r/h turn reseats it. But then there would be an increase or decrease in ride height, you could measure height when pulling left then after a r/h turn to see if there is a difference. Even then it may only affect camber and not castor. Looking forward to learning the result.
- Silverbullet
MY's don't have a top bearing like in the L series. Partly why the steering is so heavy without P/S.Cliff R wrote:What about a possible issue with the bearing on the top of the strut ?
The springs don't look like they are broken. Maybe they are turning because there is too much friction on the top "bearing"? I could try greasing it like steptoe suggested.
I am not sure why running the engine would help, but I did go under the car and have someone steer and everything seemed good except for the spring turning (top seat turning slower than bottom seat).
I will give greasing a try. Should I take it apart to do it or should I just take the cap off the top of the strut and shove grease down there?
Pretty sure the spring itself should not be turning within the seats.
EZ30 L series - Monsterwagon
I lubed the strut tops, I am not sure if that made a difference. I swapped left and right tyres, that made it always pull left but more so after turning left. I swapped front to back (the back tyres are a fair bit wider) and I think it still pulls left a little but the steering wheel shakes and the car wanders around on uneven roads.
Have you checked the leading rod bushes? When I changed these on my wagon the change was dramatic to say the least, no more tracking problems or wandering all over the road.
As noted by TOONGA you also NEED tires of the same size (and brand/make) on all four wheels. This could be a big part of your problem.
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
