Cruise Control cancelling intermittently on Outback
- thevagrant
Hi All.
I have a 4GEN Outback 5sp manual with factory cruise control.
Sometimes I'll be driving for a fair while and then suddenly the cruise control cancels on it's own. If I resume it cancels again repeatedly. When it repeatedly cancels it could be seconds or minutes between episodes.
It seems to happen when sitting near 110kmh, say on 100km/h or more. It happens on the flat at consistent speed.
Anyone else experienced this?
Thanks.
Vaughan.
Thanks.
Vaughan.
Could be as simple as your brake light switch is too sensitive and a bump could make it contact momentarily.
There are probably numerous other things that could make it cut out too.
Does the cruise light flash when it happens?
- vincentvega
- thevagrant
Ok now that you mention it the cruise control does cancel sometimes when I go over a significant bump or get hit by gusts driving into strong headwinds. The cruise light is constant and doesn't flicker.
The clutch is probably 3/4 worn at 230,000 km so could that affect adjustment? I'll see how much play there is in the clutch and brake and report back.
Thanks.
Thanks.
We had the same problem on our 04 liberty not long after we bought it new
Took the dealer some time to find the problem but on our it was the switch on the transmission. It switches the cruise off if it thinks it's been shifted into neutral. The switch was faulty and was replaced under warranty.
Could be the same issue on yours?
My first thought was the pedal switches
- thevagrant
Hi.
Just thought I'd provide an update on this. I've put higher profile /70 tyres on which has reduced the speedo reading by about 6%. Since then the cruise control rarely cancels by itself.
So there must be a speed limiter on the cruise control that trips when it's near 110 km/h. It never cancels at 100km/h or less.
Not solved but much easier to live with on the long trips now ..
Vaughan.
Vaughan.
- thevagrant
Ok another update: It's related to the gearbox. When in 5th gear if I move the gearstick left/right at coast the cruise control cancels. Also happens more when the road is bumpy and if the tyres are pumped up. Road vibration and/or moving the gearstick deliberately causes it.
So there must be a gearbox switch which is faulty.
So coopa1 I think it's the same issue as you, but took this long to narrow it down.
- thevagrant
