MPFI deadspot in throttle - blog **99% SOLVED**
Mines a 3 wire... and can also run without it connected at all... actually seams to run better without one than when it is running a busted one. Never seen a 4 wire one.
Dave
Dave
Had a think about this after reading your post Dave, so I ran it without the O2 sensor connected. Did seem to run without so much of a flatspot.
I then checked for the earth path, exhaust - body. It was of a high resistance, and knowing the sensor voltage is so low, it would affect the reading heaps. I think there supposed to be an earth wire connected some where, so I ran a new one.
Ran car with new earth to exhaust and sensor connected - result very good, large improvement!
Definately a lot smoother around the boost transition, does hold back a little still, but nowhere as bad. Still might replace O2 sensor as Subarino suggested.
EDIT: Driving around today found it was basically back to usual flatspot. This prob is intermittant and makes harder to find.
Also found out today that a 3 wire sensor is basically a 1 wire with heater, both narrow band. The 4 wire is wideband and has a different output.
- Suby Wan Kenobi
I am chasing an eradic and occasional rough idle in Dads Car (EA82T) So far ive given it a upper engine clean, cleaned the bypass air controller (was really really dirty in there) and related hoses and inlet plenum, and have cleaned the AFM, the problem is still there so next its plugs and leads.
The long road ahead
The long road ahead
90% progress Update:
Wagon has been left a tuner/repairer this week after I exhausted my capabilities.
Briefly, it has been running ultra lean, 16-17:1 air/fuel ratio.
Now has a RX Turbo ECU, improved by a huge amount. He cant put his finger on the last bit, but he is trying to achieve 12:1 A/F, currently runs 13:1.
This has been achieved by using a higher volume pump to up the fuel pressure (test only) and clamping the regulator return line. A Malpassi adjustable reg is on order and to be fitted.
Also he sees the injector pulse width maxed out along with the air flow signal at standard 7 psi boost. This is the current hurdle, seems strange this is how this has limitations, is this an RX Turbo thing?
PROBLEM SOLVED - 99%
Car now back today :P , drives heaps better, pulls evenly without any flatspot. Power does tend to flatten in the top RPM, but this is the characteristic of EA82T's. Does go heaps better, verdict - keep car now.
This is good as it gets, so I will have to be happy with that, as even more money would need to be spent.
I will look into any Jaycar kits that convert or adjust the AFM signal, as this can get a little more out of the ECU to the injectors.
An intercooler will be next and a better aircleaner and a bigger dump-pipe. This is far as I can go on the stock ECU, would need an aftermarket one if I wanted to fit the Forester XT turbo I have. (will sit on that one for now)....
Roger
Roger
Hey Jaffa, I would like to compare, and give you a drive too, cos I dont think it is as good as it could be, just a little short in top end? 100% better than it was
wrx_nut, just read the whole thread, too much to explain. It gives a pretty good process of my elimination and may give you a few pointers to start looking at. You may have similar or different symptoms.
WOO HOO - 100% SOLVED
Another post on the forum finally solved the problem.
Thanks to Suby Wan Kenobi, he mentioned a difference in injectors, being red ring ones for turbo, and grey ring ones for N/A.
Mine had 1x red and 3x grey ones. Then last w/e I got 4x red ones, fitted them today and what a difference!!!!!!!!!!
The engine now feels way different, power now stronger along the whole range, and the boost has risen to 7.5 - 8 psi. I can spin up the tyres easily now much to my surprise.
I am so glad I perservered to get to this point, cos I was close to selling it a couple of times, so on with the lift and other bits to fix (a list still a mile long)
Thanks to all replies and help on the board.
Roger
Roger
- Suby Wan Kenobi
