WRX is hating the cold starts...
Okay so I reset the ECU, well at least I think I did. Is there any way to prove it? I drove the car for a bit afterwards and it seems to drive a little smoother now. Or it could be just a placebo effect
I will test the car on Tuesday morning when I head off to school and see if it idles to 2,300 or not also if that unknown blinking light occurs.
Do I need "Throttle body cleaner" to clean out the IACV? I am also going to clean out the MAF sensor. Is there any way to check for codes even though the diagnostic plug isn't there?
Edit: I just opened up my air filter and took a couple photos of the MAF sensor. Does it look like it needs cleaning?
[ATTACH]4142[/ATTACH]
[ATTACH]4143[/ATTACH]
- 20130609_125953.jpg (95.22 KiB) Viewed 7540 times
- 20130609_130040.jpg (109.69 KiB) Viewed 7539 times
I don't think so mate. All that MAF sensor consists of is that small bit of wire in the middle. The ECU drives current into it to heat it up to a specific temp. As air flows past it cools down, so the ecu supplys more power to maintain the temp. The airflow into the motor is proportional to the current the ecu drives it at. No moving parts to gum up
Doug
Doug
Yes but no.Subydoug wrote:No moving parts to gum up.
If the sensor wire gets coated in oil and grime it becomes less responsive because the grime acts as (thermal)insulation and prevents it from measuring the true temperature/current relationship. Over oiled K&N filters are known for causing this
As for the air flow meter in question, it looks quite good.
The air flow (maf) sensors do fail, even after cleaning. The US is the cheapest to get one from. Unplug the air flow sensor and drive with it disconnected, generaly it uses heaps of fuel, but runs ok. This tends to be more noticable in stop/start traffic. If it idles/drives slowly ok all the time, it may not be the MAF. You dont need to "take appart" the IACV, just remove it and check its movemnent. The gasket is is often a "dry" pressed gasket you can carefully re-use.
L serious, still.
- littlewhiteute
Looking inside your MAF, your air filter doesn't do a very good job.Tomi wrote:Do I need "Throttle body cleaner" to clean out the IACV? I am also going to clean out the MAF sensor. Is there any way to check for codes even though the diagnostic plug isn't there?
What air filter are you running?
Gary
Gary
I will try this tomorrow morning and see if it makes any difference.tambox wrote:Unplug the air flow sensor and drive with it disconnected, generaly it uses heaps of fuel, but runs ok. This tends to be more noticable in stop/start traffic. If it idles/drives slowly ok all the time, it may not be the MAF.
A pod filter of some sort. It seems pretty dirty looking with the brown colour. I will take a photo of it tomorrow and try and find a brand on it.littlewhiteute wrote:Looking inside your MAF, your air filter doesn't do a very good job.
So I removed the connector going into the MAF sensor and stated the car. As usual the car revved up to about 2,300 for a couple seconds then dropped to about 1,500 and stayed there like it has the last few days. As I tried reversing, I stalled (not because of the engine problem, a common L plater problem). I managed to get on the road, but the car had almost no power. As soon as I got over 2,000 rpm, the car struggled to move. I went around the first corner with no "choke" or hesitation but I pulled over and reconnected the sensor as it was functioning very poorly. The car then worked fine.Tomi wrote:I will try this tomorrow morning and see if it makes any difference.
I checked Google Images and Hiclone has fins that meet in the center. I don't think my ones are stock however.Alex wrote:Is that a hiclone or something I see in the second pic? Or are those fins something stock?
Here are a couple photos of it. On the front it says "Cheetah Racing Sports" which I assume is extremely rare because I can't find any on Googlelittlewhiteute wrote:Looking inside your MAF, your air filter doesn't do a very good job.
[ATTACH]4144[/ATTACH]
[ATTACH]4145[/ATTACH]
- 20130612_081124.jpg (112.03 KiB) Viewed 7341 times
- 20130612_081111.jpg (114.77 KiB) Viewed 7341 times
