Ea81 t
Ea81 t
Just sorting out a the last of a problem i have been having with Clauida. (Details below) And the engine stalls or misses and cares on when you give it a bootful and let it drop back down to idle. Ie i basically wont idle. Any ideas???
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc. Offically now part of the 350, 000 km Club! And still pulling like a freight train.
"Claudia"
"Claudia"
Air Flow Meter ?
Have you had it running ok before?
Yes been running ok before , just had Distributor wires go. I am now thinking slightly blocked filter.
"Claudia"
"Claudia"
Try using a Uni-Filter with a very light oil coating on the outside side of the pad.
I have an EA81T if you need to try anything.
Thankfull i have 2 sitting in the back shed, including an air flow meter, etc.
"Claudia"
"Claudia"
No worries
I also have 2 cars and a bunch of parts.. wonder how many are in the country?
These are the only 2 I've seen in WA
And the filter improved some more but i am going to clean the flapper and go from there.
"Claudia"
"Claudia"
- littlewhiteute
Agree but it made it better across the rev range
"Claudia"
"Claudia"
Sounds like flooding. Stick an oscilloscope on one of your injectors. Let it idle and trigger the pwm, then floor and let it drop back down, but not stall. May be easier to get someone else to work the throttle. If the PWM is the same before and after your injectors are probably warn.
The oscope will also tell you how well the injectors are being driven. May be able to benefit from a pull down resistor.
Doug
Doug
