L series front brake disc replacement.
Post by steptoe » Sun Feb 24, 2013 12:08 am
only grease used on calipers is supposed to be a silicone grease on the sliders ? Or do the front handbrakes get grease inside the boot?
NightHawk
Post by NightHawk » Sat Mar 02, 2013 6:21 pm
The brake discs and pads replaced, wheel bearings replaced... then when I was going to test it out the fuel pump stopped working suddenly :S. I measured the voltage and it only received 6v to the pump. It seems to work fine if I put 12v directly to it. I'm starting to wish I had bought the complete service manual by now :P
Subaru GL 1800 Sedan (dark blue) 1989 In use
Subaru DL 1800 Sedan (black) 1989 RIP
Chevrolet Citation 4cyl 151cu 2500cc 1980 Given away
Lancer GLXI 1300cc 1996 Sold
Subaru Justy 1200cc 1989 Sold
Post by El_Freddo » Sat Mar 02, 2013 10:14 pm
It sounds like your subi is at the point of needing some TLC - unfortunately a lot of people give up on their old trusty at this point! I almost did, now she's gone from strength to strength thus far!
Post by RSR 555 » Sun Mar 03, 2013 10:07 pm
steptoe wrote:only grease used on calipers is supposed to be a silicone grease on the sliders ? Or do the front handbrakes get grease inside the boot?
I use a high temp copper grease on the sliders. I also use grease on the screw for the handbrake.
NightHawk wrote:The brake discs and pads replaced, wheel bearings replaced... then when I was going to test it out the fuel pump stopped working suddenly :S. I measured the voltage and it only received 6v to the pump. It seems to work fine if I put 12v directly to it. I'm starting to wish I had bought the complete service manual by now :P
I would have a search on this site, as there should be a workshop manual on here. If not get in contact with Julian (TOONGA) and he'll get you one.
Post by TOONGA » Sun Mar 03, 2013 10:28 pm
NightHawk there is one on this site
http://jdmfsm.info/Auto/Japan/Subaru/--Old%20Models--/
or this one
https://rapidshare.com/#!download|975p1 ... f|9490|0|0
have you checked either of them I remember you saying that the internet one isnt complete
NightHawk
Post by NightHawk » Mon Mar 04, 2013 1:28 am
ghostgum scanned some pages for me. The internet versions don't have the harness diagram.
Post by TOONGA » Mon Mar 04, 2013 11:37 am
NightHawk wrote:ghostgum scanned some pages for me. The internet versions don't have the harness diagram.
care to share those scans :) ?
NightHawk
Post by NightHawk » Mon Mar 04, 2013 11:55 am
Sure. I also have a engine dis- and reassembly instructional videos that I found somewhere if anyone is interested. Question is how it is best to share those on the web.
Post by TOONGA » Mon Mar 04, 2013 12:15 pm
how big are they ?
if you can upload them to a file hoster like rapidshare,netload uploaded or mediafire.
then we can download them, or you can email them to me, if I pm you my email address and I can take care of the uploading :)
miles fox from USMB has a page on youtube devoted to subaru funkiness as well :)
NightHawk
Post by NightHawk » Mon Mar 11, 2013 2:13 am
Sorry for the late reply, sure I can email them to you. But I'm in a real pickle. Seems that the electric is going haywire. I can't seem to locate the malfunction to the fuelpump. Also all the window motors stopped working except for the driver side. Weird stuff is going on. It sounds like a plug has burnt out. I replaced four relays on a rack in the dashboard without luck. I sprayed deoxit into the plug for the fuel pump by the fuel tank. No luck there. Man I wish I could rip the whole thing apart and lay the wiring from scratch properly, I just really don't want to spend any more time out in the cold :(. Alot of green stuff is forming on metals all over the car (I don't know the english word for it). Maybe the whole thing is disintegrating.
Post by steptoe » Mon Mar 11, 2013 7:07 am
think we call it verdigris, if it is forming in the wire plugs and some deoxit like sprays work well at dissolving it, just a trial and error thing. Or is it lichen like on rocks shady side ?
Do you know where the control box is for the power windows ? I think it may be under front passenger seat, under the carpet....
NightHawk
Post by NightHawk » Mon Mar 11, 2013 8:12 am
You may be on to something, I have been battling floods in the trunk. Maybe there's water damage under the carpet. First chance I'm lifting the carpet and look what's going on under there.
Post by El_Freddo » Wed Mar 13, 2013 6:25 pm
I'd also check your fusible links in the brown box near the battery. If these start falling apart strange things start happening to your electrical systems :(
Post by RSR 555 » Thu Mar 14, 2013 5:07 pm
NightHawk wrote:Also all the window motors stopped working except for the driver side. Weird stuff is going on.
This could be as simple as the "kiddie lock" on the bottom of the 4 switches?
As for the other stuff, grab a test light and multimeter and start poking around.
NightHawk
Post by NightHawk » Wed Mar 20, 2013 5:17 am
Man I have the worst luck these days. I put 12V directly into the fuel pump and cranked... still nothing. Seems my suby is falling apart on me :S.
NightHawk
Post by NightHawk » Wed Mar 20, 2013 6:23 am
Well I think I can rule out the fuel pump since there's bunch of fuel in the fuel line, unless there something clogged in the hood.
Post by RSR 555 » Wed Mar 20, 2013 12:07 pm
Have you got spark? As I know in the EA82, the fuel pump wont turn over until the engine is running (or coil is active).
I'd check that the dizzy is turning over whilst cranking. I've had a few that have broken the LHS belt.
NightHawk
Post by NightHawk » Thu Mar 21, 2013 3:20 am
Yes I got spark. I sprayed fuel directly into the carb and it ran fine for a few seconds. Do you think the fuel pump is not producing enough pressure to reach the carb? That the fuel pump itself is giving out?
Post by RSR 555 » Thu Mar 21, 2013 11:31 am
Ok. So have you pumped the accelerator and looked down the carby for fuel squirting inside?
Also, When you said you connected the fuel pump up, did you hook it up to constant 12v and it ran? how's your fuel filter looking?
NightHawk
Post by NightHawk » Fri Mar 22, 2013 1:08 am
No actually I poured fuel into the carb myself. No fuel enters the carb when I use the fuel pedal. I hooked the fuel pump up to direct 12v and it did not run. When I disconnected the fuel line by the pump the fuel filter didn't look dirty at first look.
Return to “Trouble Shooting”
