brumby running on 3 cylinders?
- jakebrumby
i have a 1990 brumby with a slightly older motor in it (not sure how much older but still an ea81) that is only running on 3 cylinders, it has spark and compression, what else could cause the problem?
- Silverbullet
If you have a multimeter or continuity tester, check the resistance of that lead whilst moving it around and bending it, wiggle the caps at either end as well. I chased ignition issues for ages and it turned out to be the lead being intermittent...the nearly new leads that is
