2002 Subaru outback H6 fuel filter location
G'day guys
Can someone tell me or post up a picture of where the fuel filter is located?
Thanks in advance:D
Thanks in advance:D
as above ^^
I also found this to be a good source for my outback questions... http://wiki.answers.com/Q/FAQ/978-1
- FROG
Filter In Tank 42072ae000 67.00
O Ring 42025ae030 1.85
O Ring 42025ae020 4.85
- FROG
If Its Not Under Bonnet Its In The Tank
Throw Me Your Vin Number And I Can "unconfuse" The Situation
- bobbyjimmy
I have a 7/2001 MY02 Subaru Outback Station Wagon.
Due to the common oil leak from the drivers side rear head gasket, the heads were just serviced and timing belt, water pump, etc replaced. However, it is at times now sluggish, particularly at low revs and noticably when changing from 2nd to 3rd gear.
I purchased new plugs, air filter, fuel filter (Ryco Z348) and injector cleaner and managed to fit the plugs and air filter, but can't find the original fuel filter anywhere!
I searched the whole engine bay; near the tank; in the boot; behind back seat; under drivers and passenger's seats and the internet without success, aside from the above posts and some USA posts that were not helpful at all
Can anyone please tell me where the fuel filter is located on this model?
Thanks
Ed
Thanks
Ed
- FROG
pm me your full vin number and I will look it up for you
Lift the rear passenger seat and under it, on the meta floor under the seat will be an oval access panel.
Under the access panel, you will find this
Then remove the electrical connector, the 3 hoses (make sure you mark which one goes where) and then remove the 8 nuts and lift up the fuel pump/sender assembly.
Once out, it will look like this (ignore the black external filter)
The metal cap must be unscrewed (a multigrip may be needed to get a grip) then remove the filter cartridge and install the new one, replace the metal cap and install back in fuel tank.
