Post
by revmax » Sun Sep 18, 2011 5:52 am
Would you believe recoing an EA81 to put in a plane is what got me into the whole brumby thing.
I still reckon fix the EA81, it will be cheaper and easier to do and you will learn HEAPS.
The EA81 has some very poor casting/maching alignment in the heads (see photos) which is easily fixed with the valves removed and carefull use of a die grinder with a rotary bure fitted.
The compression ratio std is 7.7:1, we take 1mm off the heads for aircraft use giving 10:1 ratio wich is not ideal for on the road, if say 0.5mm was removed the ratio would be aroud 9:1 but would necitate the use of 95-98 octane fuel and a little experementing with ignition timing.
BUT increased compression is not necessary for a reliable engine and the machining adds extra complication if you dont have acess to a lathe or mill.
On the learner side of things I reckon the power of an EJ ito the light weight Brumby could get a learner driver into trouble real quick, know the saying "crawl before you walk"
If you were my son we would be fixing the EA81 for 3 reasons.
1 the experience
2 so you don't kill yourself learing to drive with to much power
3 cheaper and easier to fix the EA81
http://groups.yahoo.com/group/AirSoob/
http://www.jodel.com/index.asp?p=subaru2&engines
http://www.asra.org.au/smf/index.php?PH ... 8d3033130&
http://www.recreationalflying.com.au/
- IMG_1635 800.jpg (59.38 KiB) Viewed 12052 times
- IMG_1293 copy.jpg (66.32 KiB) Viewed 12054 times
