i just purchased a 91 brumby and there was supposibly a head cracked, however theye is no visible signs of this and no water in the oil.
their is a leak at the gasket but after replacing the gaskets their is still water slowly leaking out of both sides. the heads and manifold are clean
any suggestions?
EA81 manifold
You have water leaks at the manifold jon to the heads ?
Always do a dry test fit (no goo) first without gasket to ensure things line up.
Always good idea to use genuine gaskets when available, and new gaskets, not used.
And be clean, scrape all mating surfaces with a good scraper blade
photo? of the leak and yer Brum....
