1990 ej22 fault code 30.
freakazoid
Post by freakazoid » Mon Nov 15, 2010 6:49 pm
Hi
Have just completed an ej22 conversion and appart from a dodgy knock sensor its gone well. I am however getting an intermittant check engine light and after do checking for fault codes it is showing 3 long flashes (ie code 30)
I have found only one or two mentions about it of the net but no details on how to get rid of it. I am lead to belive that it is to do with the ecu coming from an auto. Any help would be greatly appreciated.:confused:
Post by Gannon » Mon Nov 15, 2010 7:44 pm
I could no find any fault code 30 in the FSM
Here is a list of codes Subaru OBD codes
Have you tried clearing the memory?
What plugs do you have plugged in?
midlifecrisis
Post by midlifecrisis » Mon Nov 15, 2010 7:53 pm
HI Gannon
We plugged the green plugs for the test, which first up gave us the code22 for the knock sensor which we replaced and cleared the memory.
While out for a drive on Sunday a intermittant the check engine light can on for a while then off for a while and back on, this happens all the time while driving. We did a test and it showed three long flashes code 30
Marc
Post by RSR 555 » Mon Nov 15, 2010 9:41 pm
Make sure you have both the green (test) plugs and the black (memory) plugs unplugged. Code 30 is not listed as it means there is either plugs joined or faulty earth.
Paul
midlifecrisis
Post by midlifecrisis » Tue Nov 16, 2010 5:57 am
thanks Paul
Both plugs are undone, Would that be the earth for the ECU?
Marc
Post by RSR 555 » Tue Nov 16, 2010 10:01 am
Hi Marc,
Yeah the earth is on the ECU wiring.. but also check the ones on the engine.
Paul
freakazoid
Post by freakazoid » Wed Nov 17, 2010 6:44 pm
Hey thanks for the replies, It looks to have been caused by the transmission selector pin still being grounded (the computer was looking for signals from the auto). Once the wire was cut the light dissapeared, will keep an eye on it let you know for sure if that was the fault.
Post by El_Freddo » Wed Nov 17, 2010 9:37 pm
Good to hear you've got it sorted (maybe). What do you think of the EJ conversion?
freakazoid
Post by freakazoid » Thu Nov 18, 2010 6:36 pm
Its in my mates beetle, its replacing a webered ea81, as you can imagine it goes bloody well. Lots of power but also very smooth and much more drivable. Now to do my L series and Type 3............... I hate being left behind.
Post by RSR 555 » Thu Nov 18, 2010 6:38 pm
Type 3 fastbacks :mrgreen: gotta luv em
freakazoid
Post by freakazoid » Fri Nov 19, 2010 5:30 pm
yeah its a "festy", lol, currently running an ea81 and auto, its a nice cruiser, Not quick but heaps better than when it was dub powered.
Post by RSR 555 » Fri Nov 19, 2010 6:39 pm
freakazoid wrote:yeah its a "festy", lol, currently running an ea81 and auto, its a nice cruiser, Not quick but heaps better than when it was dub powered.
Pics ;)
freakazoid
Post by freakazoid » Sun Nov 21, 2010 7:18 pm
Heres one. It gets used all the time just a real nice driver.:grin:
Post by RSR 555 » Mon Nov 22, 2010 10:05 am
freakazoid wrote:Heres one. It gets used all the time just a real nice driver.:grin:
Sweeeeeeeeeet ride dude :mrgreen:
freakazoid
Post by freakazoid » Mon Nov 22, 2010 6:46 pm
Thanks, This is the baja we just put the ej22 into with my L series sedan behind it.
PIC03638 (Medium).jpg (88.96 KiB) Viewed 5528 times
Post by RSR 555 » Mon Nov 22, 2010 8:54 pm
freakazoid wrote:Thanks, This is the baja we just put the ej22 into with my L series sedan behind it.
I bet she goes a bit better now :p
freakazoid
Post by freakazoid » Wed Nov 24, 2010 6:45 pm
Sure does, i'll need to upgrade to keep up now.
Return to “Trouble Shooting”
