Trying to sort out my new My wagon and i am having trouble with the car getting way too much fuel.
Car has new transitor style coil (Bosch GT40RT), leads, plugs, very good condition dizzy with new points and vacuum mechanism, second hand carb from Suba bits which was in really good nick. Timing is good, spark is very strong, vacuum is good (EGR bypassed), cylinder compressions are (1 = 130, 2 - 145, 3 - 155, 4 - 155).
I did not touch the carb apart from replacing the float and the little plug mechanism on it and adjusting it slightly. Car is still very rich even with air/fuel screw all the way in. It fouls the plugs in about 5 minutes at idle to the point the car starts to backfire. New carb is jetted exactly the same as the old one so i'm pretty certain it is stock. Old carb has a blocked jet that is crossthreaded in and will not come out, so no good for testing.
Car starts leans out with revs but still seems rich, idle is shocking with lots of black smoke and annoyed neighbours. Cylinder 4 has random knock, maybe bent valve? As i said above it has excellent compression (consistent 155). Not sure what else to do
