OBD1980's style
OBD1980's style
Post by steptoe » Thu Mar 18, 2010 9:55 am
Ever thought with our ageing beasts (pre OBDII) that they need some sort of diagnostic panel made up and mounted in-dash, or hidden in glovebox to keep lights to a minimum. Better still, lights to glow when fault arises. Consisting of LEDs to indicate YES we have ignition power at the coil, YES we have power at the fuel pump, incorporate a headlight reminder in it so no flat battery due to door not shutting fully and draining overnight
OnBoard Diagnostics
Post by Alex » Thu Mar 18, 2010 12:36 pm
i hear wiring fun!
Post by Gannon » Thu Mar 18, 2010 2:39 pm
4 plug EA82 MPFI & Turbo ECU's supported 'Subaru Select Monitor'. But im unsure if it is compatible with the current SSM protocol
Return to “Trouble Shooting”
