Knocking noise coming from Brumby
Subaru88
Post by Subaru88 » Fri Nov 13, 2009 1:59 pm
G'day,
There is a knocking noise coming from beneath my Brumby. It happenes when she is cold, the knock speeds up as I drive and only does it when I am gear and moving. It goes away after 500m of driving.
Any advice please??
Post by TOONGA » Fri Nov 13, 2009 4:37 pm
cv joint is dry and probably needs a bit more grease
Subaru88
Post by Subaru88 » Thu Nov 19, 2009 8:09 pm
Cheers Toonga, Ill get onto it.
Subaru88
Post by Subaru88 » Sat Nov 28, 2009 11:05 am
Can I just remove the CV boot bandit clamp, pull the boot back back, give the joint a clean and then grease the joint with lithium moly grease?
Cheers.
Matt
Post by Matt » Sat Nov 28, 2009 12:34 pm
Yeah you can do it that way but it is better to remove and do it properly on the bench.
"Can I just remove the CV boot bandit clamp, pull the boot back back, give the joint a clean and then grease the joint with lithium moly grease?"
"Claudia"
Return to “Trouble Shooting”
