sticky 4wd L series
tony
sticky 4wd L series
Post by tony » Thu Aug 20, 2009 4:00 am
My 92 L series works fine in all the gears high and low, but refuses to disengage from 4wd back to 2wd, the lever just won't move, I have to rock it back and forth and wrench at it eventually it moves, but it's very annoying.
Is there some plastic joint or something that has to be replaced or adjusted?
thanks.
Post by AndrewT » Thu Aug 20, 2009 11:09 am
This behaviour is by nature for these cars. Don't wrench the lever, this is bad for everything. It happens because the L series gearbox is locked front to rear when 4x4 is engaged. On a sealed road the gearbox will start to bind up. It's why later model AWD Liberty's have an LSD in the centre instead so they can stay in 4x4 on sealed roads without binding.
All you need to do is drive a few metres on an unsealed surface like sand or gravel and it should slip back into 2wd easy. Best to do it just before you get back onto bituman after you are done offroading. Also make sure you've been driving in a straight line for a few metres, turning will also cause extra load on the gears and difficulty (this tip is in the glovebox owner's manual).
Post by guyph_01 » Thu Aug 20, 2009 12:40 pm
Yep this happens to me a lot, i had 3 L series over the years and they all did it. What i found best to work is just before getting onto bituman like andrew says, i reverse the car slowly, very slowly and sharply push the leaver down in 2wd. Works great :P
Dont go crazy on the lever "rock it back and forth and wrench" as this is not good. Its just like andrew said, they bind up and you just want to gently unbund them :P lol
P.s be gentle and its gonna work and somethimes you may need to go at it a few times.
Post by Subafury » Sat Aug 22, 2009 10:41 am
keep the wheels straight drive slowly and give it a quick smack down into 2wd. or do it before u hit the blacktop.
Post by steptoe » Sat Aug 22, 2009 10:48 am
same here with mine. I was having to wrench the bugger even when on dirt but found to stop rather than doing it mid fly was better and shift back to 2WD at very slow speed on very slippery surface like wet grass or loose gravel. Also worth mention is keepng to same brand and size of tyre all round
imbd852
how to choose
Post by imbd852 » Mon Sep 14, 2009 1:17 am
I was just about to buy lace front wigs on saturday!! They didnt have the style swiss lace wigs I wanted in a short length, So i was bout to get this one, but he lady talked me into a longer length cheap lace front wigs in the orignal style lace wig:http://www.royalmewigs.com I wanted. Im jeolous now!!
Return to “Trouble Shooting”
