It is fine to use the cam timing marks [as opposed to ignition timing marks] to set the belts right and to stuff around sticking a finger in the plug hole and feel the comp coming up but...using correctly tensioned belt.....
I found that to have the timing belt cover off the RHS/drivers side in RH Drive lands/ turbo side - on the EA82 & T and line up one of the four holes of same size in cam belt sprocket line up centrally with the timing cut in the plastic back plate. With the fly or flex plate on TDC I found it is the hole that has the single tiny hole [used for cam belt line up] to its left when looking at it from the front.
Setting up the belts this way allows the dizzy to be checked and/or adjusted to help prevent having dizzy out by 180 degrees or whatever, in theory anyway. Number 1 is in the cap one closest to firewall in my case.
note to self: I used the first option for forums to get it to show here like this on imageshack.us
